Sponsored by: Real Truck
Radius Arm Problems
Old Oct 23, 2025 | 04:20 PM
Chsapk1's Avatar
Chsapk1
1st Gear
Radius Arm Problems
How can you tell if the bushings in the Radius Arms on the front suspension are bad?
Old Oct 23, 2025 | 04:52 PM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
Early signs would be excessive wandering and bump steer. If they are bad enough you will probably have some suspension noise like clunking. Easy way is take a big pry bar and stick it between the frame and the bar to see if it has too much movement. It shouldn't really move at all. Best way is to have it on an alignment rack and check the castor of the axle and see if it has any "steer" built in. What I mean by that is does one wheel sit further back than the other.
-Dan F
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Whitey Ford
Jul 27, 2023 07:06 PM
ocracokenc
Dec 16, 2020 05:37 PM
OffRoadF-150
Offroad & 4x4
Jan 4, 2006 01:32 PM
geowing
Oct 9, 2004 01:55 AM
jad
1978 - 1996 Big Bronco
Nov 11, 2002 09:27 AM
