Core support difference 2WD/4WD?
Old Oct 23, 2025 | 12:47 PM
67/99_f450's Avatar
67/99_f450
I have a guy looking for a core support for a 68-72 4x4. I have one but it is from a 67 F350 2wd. I can't imagine Ford would make a different core support for 2wd and 4wd but I have been wrong in the past. Can someone enlighten me on this?
Old Oct 23, 2025 | 02:40 PM
fe390pc's Avatar
fe390pc
Here is a great article on all the different core supports. https://www.fordification.com/tech/radsupport.htm
Old Oct 23, 2025 | 03:05 PM
67/99_f450's Avatar
67/99_f450
I have the taller of the two core supports in my 67 F350 with the larger opening which leads me to believe this may also fit the 4x4 trucks?
Old Oct 23, 2025 | 09:08 PM
1browski's Avatar
1browski
That was my understanding. I had a 72 f250 4x4 with a bit of a bent up core support. I also have a 70 f350 that had the same core support, I swapped them out. Both trucks used the same big radiator.
Old Oct 23, 2025 | 09:11 PM
RichS2659's Avatar
RichS2659
Here is the scoop from Jefffafa:
C7TZ16138A....67/72 F100/F250 4X2...w/o Super cooling/////C7TZ16138B....67/72 F100/F250 4X2....with Super cooling, all 4X4, and F350.
C7TZ16138A took radiators with a 19 3/4" core height radiator.////C7TZ16138B took radiators with a 24 1/4" core height radiator.
swarf_rat
6.7L Power Stroke Diesel
Jan 26, 2022 05:19 PM
sgettin
Dec 5, 2009 03:08 PM
doc66
20
Apr 10, 2009 07:01 AM
gangstakr
Jun 7, 2008 07:44 PM
