...What!?...another computer problem???
Old Dec 8, 2003 | 12:08 PM
wabiker's Avatar
wabiker
...Yall are the closest thing to experts that I know...so here goes...
...I can sign on to aol, but it takes at least three trys, I get the home page but it wont let me access any thing else...I get a "aol error" message that tells me to sign off and restart the computer and try again.
Ive tried reformatting...everything
Apparently my modems working...
I tried the IE repair option...
I have window 2000 proffessional...
Any ideas....? Ive thought about trying one of those eraser programs and starting over...I spent most of this weekend trying to figure this out....'Bout ready to take my 12ga to the whole thing....
Old Dec 8, 2003 | 12:10 PM
Matts72's Avatar
Matts72
You have the aol***** virus. Delete it from your computer asap. It makes you dumber!
Old Dec 8, 2003 | 12:12 PM
joadmobile's Avatar
joadmobile
Sounds like your AOL aoftware is bad. If your modem is connecting I doubt if it is the problem, but to double check you could try setting up a NetZero account or dialing into a fax machine and sending a fax. Can you reinstall the AOL software? Or even better, dump them and go with somebody else?
Old Dec 8, 2003 | 12:35 PM
wabiker's Avatar
wabiker
...Impossible....there is no possible why I can get any dumber...
Old Dec 8, 2003 | 12:37 PM
wabiker's Avatar
wabiker
I tried the reinstall...I just want to make sure that the problem is not on my end, before jumping on some body elses bandwagon...
Matts72's Avatar
Matts72
True, you will only get smarter.
AOL blocks your IQ from going above 85.
As soon as you delete the virus AND call the number your IQ, spelling, and grammar will dramatically improve.
Old Dec 8, 2003 | 12:42 PM
theologian's Avatar
theologian
That sure seems correct...
Theo
Old Dec 8, 2003 | 01:00 PM
Andysutt's Avatar
Andysutt
Get DSL or Cable
That'll solve your problems
Old Dec 8, 2003 | 01:19 PM
paulv107's Avatar
paulv107
Did you recently install AOL 9.0? If so, that is probably your problem. Everyone that I have talked to personally and people on the various forums I visit have had nothing but trouble with the 9.0 version. They all say that it does wierd things to your computer. I know, I upgraded about a month ago and had to uninstall it because I had nothing but problems.
If you did install 9.0, try uninstalling it and going back to the previous version you were using and see if that helps. I did that and haven't had any problems since.
Old Dec 8, 2003 | 02:13 PM
wabiker's Avatar
wabiker
....Done deal....although they dont make it easy do they...??
Ok, now Im sitting back waiting for the smart juices to flow..
Old Dec 8, 2003 | 02:15 PM
wabiker's Avatar
wabiker
Andysutt: I wish I could afford DSL or Cable
PaulV: Nope, I thought about it and almost did it but the computer froze up before I could load it. (as I was reading about it actually)
Old Dec 8, 2003 | 04:12 PM
Matts72's Avatar
Matts72
It might take a couple hours for the full effect to hit you.
Old Dec 8, 2003 | 04:17 PM
Andysutt's Avatar
Andysutt
Drink a beer. it'll keep the smartness from attacking you all at once
Old Dec 8, 2003 | 04:31 PM
Jmatteau's Avatar
Jmatteau
your problem is you have aol
Old Dec 8, 2003 | 05:01 PM
BuiltToughF250's Avatar
BuiltToughF250
WABIKER, sorry if this had been mentioned cause i skipped all the reading but i recently started having the same/similar problem...
just a question- do you have Kazaa ? its the music sharing network like napster.... since i installed that again on my comp. ive been having problems, so once i get the songs i need im deleting kazaa
