Identifying Ca vs Fed ecu
Old Oct 18, 2025 | 06:18 PM
Rjustinpalmer's Avatar
Rjustinpalmer
4wd Low
Hey guys,
I’ve been having trouble with my truck running when the SPOUT connector is plugged in. I pulled the ECU to check it and it looks good, but according to chat GPT the truck is a Ca truck and the ECU is a fed truck. Is there any way to confirm this? Wondering if someone replaced it with the wrong one and then just left the spout connector removed because they couldn’t figure it out (spout was removed when I got the truck).
The outside of the ECU ends in -ATA which according to chat gpt is fed spec but circuit board inside ends in -ca which is supposedly CA spec.
could this be the issue with my truck?
Old Oct 20, 2025 | 11:04 AM
jas88's Avatar
jas88
How about you start by telling us what your truck is?
Old Oct 20, 2025 | 04:00 PM
rla2005's Avatar
rla2005
Some info on Calibration Code 0-98A-R10: https://www.ford-trucks.com/forums/1...l#post20966188
TLDR.....the PCM number you are looking for is F0TF-12A650-ATA which has Federal emission programming.
The -CA alphanumeric on the circuit board does no imply it is a California emission PCM.
Please further define your symptom statement: "I’ve been having trouble with my truck running when the SPOUT connector is plugged in."
Old Oct 20, 2025 | 04:23 PM
Rjustinpalmer
4wd Low
Truck issues
so it’s a 1991 F250 with a 7.5 in it. Without the spout connector installed it seems to run ok but when I plug in the spout connector it struggles to run, it will loap like it’s running on just a couple cylinders.
Old Oct 27, 2025 | 12:46 PM
rla2005's Avatar
rla2005
The photos of the computer look good to me. But looks can be deceiving. Have you recently run the Key On Engine Off (KOEO) codes and Stored Code display to see if anything is flagged? You can have stored codes without a Check Engine Light (CEL).
hunts318
Large Truck
Jan 2, 2025 07:12 PM
PyroDroids
Apr 23, 2024 12:19 PM
Hustlinismygame
Sep 9, 2023 09:02 PM
Jared H
Sep 29, 2020 10:03 AM
calvinhg
Jul 5, 2020 10:10 PM
