03 Excursion Limited - Dome Light Replacement
Old Oct 17, 2025 | 05:39 PM
SAARNO's Avatar
SAARNO
3rd Gear
So, after 22 years, one of my dome bulbs finally went out. Bought Sylvania 921 pack of 2. I removed dead bulb socket, and in removing bulb from the socket, I saw the leads from the bulb (normally looped along the wedge base) had been straightened and spot soldered to the socket contacts along the side. Got the bulb out, and inserted new bulb. But the looped leads do not reach the socket contacts. I will clip, extend and re-solder leads from new bulb to socket contacts.
Curious if anyone else has seen this configuration with wedge-style bulbs. I checked the working bulb and it is setup in the same way.
Old Oct 17, 2025 | 10:27 PM
John in OkieLand's Avatar
John in OkieLand
IIRC,
the only time I found something like that, I just cut it out, and found a replacement socket.
Old Oct 18, 2025 | 05:30 AM
01__Excursion's Avatar
01__Excursion
So many of us have switched to an LED bulb as the heat from the incandescent just degrades the fixture.
Old Oct 18, 2025 | 07:42 AM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
There are also LED kits that you can purchase if the ribbon cable and plastic has degraded such as this one on Etsy.
Old Oct 18, 2025 | 11:46 AM
John in OkieLand
the Fire Department pulled the bulb out of mine, and installed an LED strip of WHITE lights around the entire fixture, and it is either ON, or OFF, by pushing the light switch on the ceiling... the door has no control over it.
mikekozak
Jul 3, 2021 06:45 AM
dx3
Aug 20, 2017 09:30 PM
SShank42
General Automotive Discussion
Jul 14, 2007 08:03 PM
ferreed
Electrical Systems/Wiring
Jan 5, 2006 10:32 PM
