Window felt strips
Old Dec 8, 2003 | 10:09 AM
BullDog58's Avatar
BullDog58
Question Window felt strips
I need a little assistance. I have converted my 58 to the larger single side glass (eliminated the wing glass, built a full lip from the back to the front of windo area, etc).
It all went well, except (there always seems to be an "except" with this old beast) now I cannot find a 1 inch wide felt lined belt weather stripping to put at the base of the window. These are the pices that go on the inside and the outside of the window. They attach to the door and reside at the base of the window on both sides.
What I really need is some that has that stick strip on it, kind of a peal and stick on application.
I have looked at JC-W!@#$ and others, but I am not sure if they have what I need. Like I said if I could find one inch wide strips that have that stick strip on it I would be set.
Any help is appreciated.
Old Dec 8, 2003 | 12:14 PM
LEckart's Avatar
LEckart
BullDog58
You probably already know this but MidFifty and others make the Lower Felt Wipes for the modified full window 56, Is that close enough to work on your 58 size-wise?
Larry
Old Dec 8, 2003 | 12:25 PM
57_Fordguy's Avatar
57_Fordguy
sacramento vintage ford also sells them.
Corpsman24
Jun 24, 2013 11:06 AM
Roamer
Feb 19, 2009 12:25 PM
Ira Brown
Feb 26, 2008 04:17 PM
shadowdd
Feb 7, 2006 09:37 AM
JBronco
1978 - 1996 Big Bronco
Apr 24, 2005 06:42 PM
