Sponsored by: Auxito
pre bid counsel, please
Old Oct 13, 2025 | 01:45 PM
tehutton's Avatar
tehutton
I'm considering a 2000 F-150 extended cab 4 wd listed at an estate sale near me. It looks good in the pictures and I plan to inspect it in person before bidding. The auction carries this warning "This truck starts and runs. Note: the speedometer and odometer are not functioning, and the power locks are inoperative. The truck required a jump start to get running," In addition to general things to look out for specific to this era of truck, can anyone tell me if I can access the odometer through the OBD port? I have a couple of fairly basic scanners, as well as a jump box, that I could take to the onsite inspection. Many thanks for your advice!
Old Oct 13, 2025 | 01:48 PM
charlie g's Avatar
charlie g
FTE Community Team
\ personally i would run not walk away.
Old Oct 13, 2025 | 07:07 PM
irhunter's Avatar
irhunter
Good idea about scanning for codes. It is my belief that the quality of your scan tools determines if you have access to mileage. I, for instance, have a super-basic code reader that does not do mileage.
IMHO, the model year 2000 was not great for the engines Ford put in the F150s. The modular motors had the well-knows spark-plug-hole-stripping problem. I think of the 4.2 V6 to be the best of the F150 2000 motors.
I would get on Youtube and search Everything Wrong with 2000 F150.
Good luck! Report back.
Roy
Old Oct 13, 2025 | 07:45 PM
BareBonesXL's Avatar
BareBonesXL
Pretty sure the speedometer uses the same sensor as the odometer. So if by "not working" they mean not recording mileage because of a bad sensor, seeing mileage via OBD might not mean much. It hasn't been recorded.
On the other hand I know that speed is shown in live data with my simple bluetooth scanner via a phone app (Piston). If you can drive it or jack up a wheel and put it in gear you might learn something. If it shows speed, it might be a cluster issue. And, the typical odometer problem is often connected to whether or not the headlights are on. Works when they're off, not when on.
Engine and transmission make a difference. You didn't say what it has.
Old Oct 13, 2025 | 11:27 PM
Oregon Kickstart's Avatar
Oregon Kickstart
Roy
I personally love my 5.4l modular V8 engine. 250,000 miles and never blown a plug out. Run's like a monster...
Old Oct 14, 2025 | 03:58 AM
manicmechanic007's Avatar
manicmechanic007
If you get it running and it runs good, offer them 800 bucks
That way you can afford to put an engine in it someday and to fix the speedo now
Look at the pedal rubber et al. to determine mileage
Assume it has 300k unless they can convince you otherwise and the pedals look new
Old Oct 14, 2025 | 12:36 PM
tehutton's Avatar
tehutton
We had the same thought of getting it running and offering a price low enough to not get hurt too badly (I was thinking $1K so we're not far off). But don't think that's going to happen. 8 days left on the auction and its already at $2,213 ($1876 and 18% seller fee). For what it's worth, I'm guessing this was a 5.4 motor based on I could see a trailer brake control in the interior pictures and both front and rear mounted hitches. This thing got used for its intended purpose, I'm guessing hauling horses. Interior looked like an older person's vehicle -- seat cover, dash pad and steering wheel covers -- and that it was driven into the driveway and parked. Might be a good deal for someone who wants to take a gamble or knows the truck. I'll stick with the "devil I know," a well worn 87 Ranger. Thanks for responding and offering counsel!
Old Oct 14, 2025 | 01:20 PM
BareBonesXL
Post the link so we can look at it, just for fun.
Old Oct 15, 2025 | 01:53 AM
Oregon Kickstart
Talking
Your post made me chuckle a little. I bought my 2001 5.4l 4x4 SC like three years ago. The worn out brake pedal rubber bothered me, so I ordered a brand new one through Amazon... I wonder if that might up my value a little if I sell it? Just kidding! I am keeping this one for quite awhile. Even if I get a newer one... I just love the truck that much. Barring of course a serious accident, roll-over, or something catastrophic...
Old Oct 16, 2025 | 12:00 AM
SDDL-UP's Avatar
SDDL-UP
My 2000 5.4 has over 364,000 miles, also never blown a plug!
Failures? Intake manifold, two coils, replaced all the coil boots, had to clean the idle air control valve a couple of times, water pump once, two alternators and had to re-crimp the radiator once with vice grips. I think that's all the engine related things!
Old Oct 16, 2025 | 02:23 PM
Pickupmanx2's Avatar
Pickupmanx2
I'm buying my old work truck back, with 221k on the clock, I put 210k on it from '02 - 2015 before I changed jobs, I plan on running it another 100k at least, my brother had a 2000 F150/CC 2wd with the 4.6 and he was closing in on 400k when his trans started going out and he sold it. The modulars get a lot of hate from those that had the plugs spit out, but in reality, they are great motors IME when maintained properly. I bought a 2000 Excursion 2wd/5.4 last year with 136k on it and I plan on getting it to 300k at least. My old work truck is a 2000/Scab/4x/5.4 7700/7 lug, my daughter is driving our Expy 4x with the 4.6 and it's at 190k, plan on her driving it for another 100k so she doesn't have a payment.
Old Oct 17, 2025 | 02:44 PM
STOFFERJ's Avatar
STOFFERJ
the cracked solder on the dash cluster?
the lock actuator burnt out? both super easy repairs
fasthauler
Sep 18, 2024 02:48 PM
JimmyWayne23
16
Jul 30, 2022 12:57 PM
78ford351m
Nov 12, 2008 12:18 AM
smpol19
Dec 31, 2007 12:06 PM
