Fuel-related problem?
Black Ranger, I was going to clean out my MAF, JUST in case that could still be potential culprit, but even with a torx security bit, I could only remove on of the screws on the MAF sensor. The other screw has a tiny plastic cap on it, and when it was removed, the plastic broke off, filling the grooves on the screw head. (Arggghhh!) I'm going to try to remove the screw with some pliers though. I did the "tap test" thing, with the MAF, and the idle didn't change, so I don't know whether it might have been the problem or not. (or at least part of it) My truck does have almost 170,000 miles on it, and I don't know how well the truck was maintained by the previous owner. (it starting to seem like it was poorly-maintained though) I think I'll change the MAF in the next few weeks, if I can't clean it that is. With such high mileage on my truck, it can't possibly hurt. I also think that I'm going to clean the IAC too. My truck still has a slightly, and I mean very slight, "rough" idle. ("rough" is the only word that comes to mind)
Actually Black Ranger, my CEL did come on twice during my first drive after I changed the cap/rotor. It came on then went off, during my test drive. The other night, Sunday, the CEL light came on while I was driving again, but after I stopped driving for the night and drove the truck the next day, the CEL has not come on since.
As I said though, I'm going to change the MAF. Also, earlier in this post, KEN00 mentioned that it might be the TFI ignition module. As per his suggestion, combined with what I've researched, I think I'm going change that in the next couple of weeks too. I'm just trying to do a component at a time, so as to be able to more readily pinpoint what might have been causing the problem. I'm also trying to not spend money needlessly. (although it's probably money well spent, considering the big picture of wanting my truck to last...) I guess the only other thing I'll end up changing will probably be the 02 sensors. After all, it's probably something I should change due to the mileage. I'm also going to change the transmission fluid as well. I bought the last July, but I haven't changed the fluid yet, and there's no telling when the previous owner(s) changed it, if ever.
Ken00, since you mentioned the crusty stuff on my distributor cap was dielectric grease, should I take the cap off and put some of that stuff on the contacts? I didn't do that when I changed it. Also, should I put some dielectric grease on the rotor contact as well?
Black Ranger, how much did your MAF cost? The cheapest I've seen has been at partsmamerica.com for $63 or so. (remanufactured) Actually, that brings up a good question... the phrase "You get what you pay for..." does anyone think this applies to the MAF? I not exactly sure whether I shoul get a new one or a remanufactured one. I've had other remanufactured parts from vehicles I previously owned, and those parts worked fine. Any opinions on whether "You get what you pay for..." (about vehicle parts that is) is true or not?
Until the my post, (which I hope will be a bit less problematic in origin) take it easy everybody.
-Mike-
good luck, hope you fixed it.
Get the codes pulled from the CEL going on, that should help. I paid about $65 for a remanufactured one and had no problems with it. A lot of people will tell you otherwise, but I've never had any problem with the remanufactured parts. I figure in the case of the MAF, it was much cheaper and easy to change, plus the part came with a warranty. I bought mine from partsamerica also, which is what Checker Auto uses.
If you use a dremmel you can cut through the security torx heads and take them off with a regular screwdriver.
A small pair of vise grips worked for the epoxy filled security torx bolts on my 97 4.0's MAF.
Don't use carb cleaner to clean the maf either. It does leave a film. Use something like Electrical Cleaner from CRC. You can find it at most autopart stores. Plus you can use it to clean the rest of the connections on all your sensors if needed.
Use some di-electric grease when you plug your MAF connectors back together. For that matter use it on all your electrical connections you take apart and on both sides of your plug wire boots. Makes it easier to take'em apart later on.
Also, There's lots of talk online about different plugs/wires and what to use on the 4.0's. Not sure if it applies to the 3.0 but from what I've gathered from reading everything most people that have some type of miss or stumbling idle are the ones that used bosch platinum plugs and/or cheap wires. I had a miss due to Bosch wires.
