'77 brake lights out
** The brake lights run through the turn signal switch
Find the wire that feeds power from the brake switch into and out of the TS switch
Verify that power is going in and coming out
Once you do that, there is another connector for the rear harness near the column under the hood
I replaced the whole column turn switch a while back on a '78 and can't remember if I had to pull the steering wheel off or not....?
Must've been sometime year 2022 early. I was headed south on the interstate doing 68-mph when a front tire sidewall let go.
The tires were BFG a/t's in size 35-inch on 16-inch wheels. Ther tires were new in around 2002, so, real old but held air.
Anyways the Van held a straight line, and I had to force a turn-out spot at a steep cut uphill side.
Those semi-trucks made me super nervous as then whizzed buy seemingly inches from the Van.
Anyways, from my best memory, the Hazards didn't work. _ _ what's new there, right ! _ _ especially with an older vehicle.
At the time, I was "chasing gremlins", as I had recently pulled the van out of a 17-year hibernation.
Ok, after a long list of faulty pieces and parts like 23-items, the Van was dependable to drive without worry.
Oh, and yes, late 2022, I had new BFG 285/75-16 mud terrains installed for peace of mind.
I chose to go to a 32" tire from the previous 35's for better braking response and driveability.
I get home from running an errand around the month of April 2025, and my wife says "Your Brake Lights DON'T WORK."
Omg, after doing extended research on the internet, I discovered that the Hazards and Brake Lights are on the same circuit !
At that point I felt like a real IDIOT, for not having checked the brake lights earlier.
The culprit wound up being the fuse up at the upper left corner of the Fuse Block, so was an easy fix.
For checking for power, I took a seat belt buzzer, and added alligator clips to each of the two wires, and I like it.
Since fixing the Brake Lights and Hazard Lights with a simple fuse change-out, I've been sprinting around with a Smile.
Like @manicmechanic007 suggested, make sure you have power in and power out of the switch.
And that the Hazards flasher is functioning.
Yes, you need to pull the steering wheel to replace the switch. The wires come up and out from the top of the column to replace the switch
I never mess with replacing just the cancel cam that you CAN still get from the aftermarket
Unlikely the switch is the fault for the brake lamps unless it's shorted
** Unless things like hitting the brake and the RF turn signal comes on, are happening
To fix this I have cut open the white plastic socket to then solder the contact for continuity of the ground.
Could this be a culprit ? _ _ _ or would this only affect just the one bulb ?
I found the expected broken tab from the cam lying in the turn signal switch, it wasn't causing any problems.
Then the memory of replacing the switch/harness on an former van came back to haunt me so I stopped because the switch looked fine (except the cam of course). As it stands, we're still at square one. I will scope out the tail housings next, then I'll call for backup with a good multimeter...
I still have one
You can plug one into your harness and see if the problem is fixed
Then decide if you want to hassle with replacing it
I wouldn't replace it either, for just a broken cancel cam
This makes me wonder if the end of the shaft coming from the booster (in green).... the push rod? - specifically the metal ring that goes over the brake pin and sits between the two sides of the switch - where it contacts the switch should be flat / square? IIRC the one on there now might not be flat on the outer side like the one pic below...?
The push rod looks pretty beat, but still seems to have a flat enough mating surface. I tried a metal shim (using one of those old PC card slot covers) but I think a thicker one might be needed, i.e. the switch still wants to creep upward and not activate the lights. When strapped down with zip ties it's ok, but that's some hillbilly BS I hate doin'.
