Brake lights
Old Sep 30, 2021 | 08:05 PM
Nitro1168's Avatar
Nitro1168
Brake lights
I have a 79 f150, I can’t get the brake lights to work. I jumped the switch, checked the fuse and don’t have power coming out of that fuse. Where can I look next?
Old Sep 30, 2021 | 10:45 PM
440 sixpack's Avatar
440 sixpack
I assume you meant to say you do have power out of the fuse.
Do you have power to the bulb socket ? if so check the socket and the ground. if not it could be your turn signal switch.
Old Oct 1, 2021 | 05:10 AM
Nitro1168's Avatar
Nitro1168
I do not have power at the fuse, no flashers either
Old Oct 1, 2021 | 08:02 AM
davelj's Avatar
davelj
These trucks can have fuse box issues. Sometimes corrosion on the back side of the box can cause a circuit to lose power. Try taking out the screws holding the fuse box and see if you can look behind it for problems.
Old Oct 1, 2021 | 09:08 AM
440 sixpack
Then you don't have a brake light problem you have a power supply problem.
Old Oct 6, 2021 | 08:54 PM
Nitro1168's Avatar
Nitro1168
The fuse holder was rusted, plus I was looking at the wrong fuse lol, thanks for the replies.
russell christy
Sep 26, 2013 06:27 AM
cturner41314
Large Truck
Feb 27, 2011 06:56 PM
brseidel
Oct 15, 2010 08:31 AM
jschloes
1983 - 2012 Ranger & B-Series
Sep 27, 2003 06:44 PM
