Looking for compatible axles for my van. Axle code is 24, 10 bolts on the dif, semi float, 3.73. I’m like 90% sure it’s a Dana 60 and a 30 spline. My question is will any year axle shaft be a drop In replacement if the axle code matches? Is there a source on line to order a new set? I’ve include some nomenclature photos. Any help is appreciated. I can’t find much online.
Ok I’m about to be in the Salt Lake City area so I’m sure there is someone in the area. Ultimately my plan is to swap this rear end with a full floating so hoping I can find something in a junkyard in better shape than mine. Thank for the reply!
You should have no trouble finding either a full float axle or the axles for yours in SLC
You can search the pic a part yards website inventory online
They all have vans and quite a few of the 3/4 tons were full float
Quite a few were like yours too
Pic a part and tear a part both have online inventory resources
Yeah there are like 3 big yards all in one spot so I’m hoping I can find replacement axles easy for this rear end!
Unfortunately I’m still having trouble finding a complete list of compatible “drop in” rear ends.There were so many different rear ends manufactured even among years and models. But your right in my research there does seem to be some E250 full float rear ends out there, but also it seems like some e350 vans might have drop in rear ends for my van as well all the way up to the early 2000s. I’ll just have to get out there and look I guess.
I just want to clarify this for anyone who looks at the thread later. This rear end is a Dana 60 35 spline driver side is 34 3/4in + or - 1/16 passenger side is 31 5/8
