Leer bed cap lock
Old Oct 2, 2025 | 02:24 PM
H-D Dad's Avatar
H-D Dad
Leer bed cap lock
My cap used to lock with my truck fob 2017 f250 6.7, quit doing that. I am trying to trouble shoot.
My first guess was to check voltage at the lock while locking and unlocking the doors. So my question is do the door locks get a shot of 12 volts to operate?
Any other ideas would be most welcome. Thanks
Old Oct 2, 2025 | 04:55 PM
muisejt's Avatar
muisejt
voltage is sent to the actuator. it would be best to use a test light or an analog multimeter since it's a short duration and a digital multimeter will probably not register anything
Old Oct 2, 2025 | 06:07 PM
HorizontalHunter's Avatar
HorizontalHunter
This; or if you have access to the wire connection you can pull the wires for the actuator and hit it with a 9v battery. It should be enough to activate the actuator.
Bob
Old Oct 2, 2025 | 06:22 PM
H-D Dad's Avatar
H-D Dad
I was able to use a battery to test the actuator, it works. To lock it blue to pos, green to neg. To unlock blue to neg, green to pos.
It stumps me to figure how to test the wires coming from the truck. If anyone has a procedure for that please let me know It is 2 wires , a green and blue. Thanks
Old Oct 2, 2025 | 07:01 PM
HorizontalHunter
You may just have to follow it out to see where they tied it in.
Bob
Old Oct 3, 2025 | 10:21 AM
H-D Dad's Avatar
H-D Dad
Got it fixed. Had 2 problems, a bad crimp under drivers door sill, and a fuse under the bed that needed to be cleaned up. Thanks for the help getting it figured out.
Old Oct 5, 2025 | 03:10 PM
T. Banning's Avatar
T. Banning
Eliminate the crimp, and solder and heat shrink it!
4sabre
Offroad & 4x4
Dec 17, 2010 03:39 PM
97ExplorerEddieBauer
13
Apr 8, 2008 06:09 AM
mrc59
Oct 29, 2006 07:50 AM
spoon059
Mar 12, 2003 04:42 PM
