Neutral Safety Switch
Old Sep 27, 2025 | 09:07 PM
w951wxj's Avatar
w951wxj
Got the safety side of the NSS switch all set up and good - Red/blue chasers wires, 2 of them are all set and working - truck starts in park/N and not in any other gear. That leads me to 3 other wires on the connection plug. Reason I ask is this is a fresh wire - almost all wire was ripped out with only some connectors left - this happens to be the original connector and it has the 2 red/blue wires, it has 2 black/red chaser wires and 1 solid black wire. My question is does anyone else have this 5 wire combo and where do the 3 wires left go. I know at least 1 had to go to reverse lights, and my guess is there is an incoming reverse light power and then out wire to the lights so the 2 black/red chaser wires might make some sense - power in, power out but then what the heck does the solid black go to? is it one of Fords famous "not used wires"
Old Sep 27, 2025 | 10:02 PM
tbear853's Avatar
tbear853
Connecting the two red/blk wires together turns back up lights on.
Connecting the two red/blu wires together enables the starter.
I don't know about the black wire as mine (a '77) does not have it. Switch is mounted on steering column in cab under dash on '73-'77 s.
Old Sep 28, 2025 | 07:14 AM
w951wxj's Avatar
w951wxj
Yeah same - I figured the two black/red would make the back up circuit - just no clue on the solid black. All the power from the backup lights must come from the red/blue and flow through the NSS - is that correct/
Old Sep 28, 2025 | 11:10 AM
tbear853's Avatar
tbear853
The back up lights and neutral/park interrupt functions are totally separate. They use their own separate contacts in the NSS. It is commonly known as a "Neutral Safety Switch" .... but it is really a "Combination Neutral Safety and Back Up Light Switch".
When the key is on Accy or Run, one of the red/black wires is hot. When the correct contacts are aligned in the NSS the current can the flow to the other red/black to find it's way to the back up light bulbs out back.
The red/blue wires are only used in the path to the starter relay, and only when their contacts are aligned in neutral or park (properly adjusted NSS), can current find it's way to the S on the starter relay when the key is turned to start.
When I accidently broke the flag that moves the pin of the NSS when replacing a cracked shift collar, I ran four wires from two simple toggle switches for a while and by flipping one to on, NU lights lit. By flipping the other, truck would start in any transmission position like P-R-N-3-2-1. After fixing the broke flag by snapping a new one in, I left my NSS bypass switches in place. I can use them like to illuminate the rear while hooking up a trailer, etc, or ... if that new flag broke, I could still start my truck.
Old Sep 29, 2025 | 07:14 AM
w951wxj's Avatar
w951wxj
@tbear853 I could be reading your post incorrect. On my column mounted NSS I have 1 Red/blue chaser wire that comes from Ignition to the switch and 1 out to the starter exciter...that circuit works perfect/all aligned - I can only start in Park or Neutral. What I'm foggy on is where power comes from that provides the power for the reverse lights or does one of the Black/red wires connect up to a power source and the other out to the lights? Once I get that sorted, I still have no idea what that 5th (solid black) wire does since no one seems to have that. Truly cold be some later mod the owner did but it surely looks original.
Old Sep 29, 2025 | 07:28 AM
w951wxj's Avatar
w951wxj
@tbear853 I think I figured out the backup lights. In the kit I have, there should be a fuse box wire for 1 of the Black/red wires and the other out to the backup light - okay, that clears that up. Black wire - I'm just gonna tape that over. I did see somewhere that someone thought it could be related to a cruise control circuit but this truck is bare bones, there never would have been cruise on this. Again, its it 52 years of life, someone probably used some parts or modified something somewhere along the way - who knows.
Old Sep 29, 2025 | 08:48 AM
tbear853's Avatar
tbear853
On my '77, the back up light power comes from same 15A fuse as do turn signal flashers and the windshield washer pump. If key is off, no power through it.
Makes sense on the black wire.
Old Sep 30, 2025 | 10:30 AM
w951wxj's Avatar
w951wxj
Figured out that single orphaned black wire coming out of my NSS connector - camper reverse lights. I don't have the camper shell although I do suspect that maybe this truck did at one time as the top of my bed rails are total junk/rusted and bondo'd.
Old Sep 30, 2025 | 10:47 AM
tbear853's Avatar
tbear853
Oh. you mean like a large slide in camper that would have blocked the bed back up lights? So, it has power when the trans is in reverse? Makes sense, I've read "speculation" it was a ground, or something dealing with CC?
Old Sep 30, 2025 | 11:33 AM
w951wxj's Avatar
w951wxj
Right - i would have suspected ground too but you are right - the big slide in 2 person type camper on the bed of the truck
bryanmartin
Apr 25, 2018 12:01 PM
Jax Rhapsody
1978 - 1996 Big Bronco
Mar 24, 2011 06:55 PM
Tattooed_countryboy
Electrical Systems/Wiring
Feb 18, 2008 07:02 PM
dichdoc
Sep 15, 2006 10:33 PM
just1me
Oct 10, 2005 01:57 PM
