'57 Small block/top loader swap
Old Sep 25, 2025 | 05:33 PM
BCP9875's Avatar
BCP9875
Trailering
I called one of dads ol buds today that still junks some and was asking about 57-60 F-100 parts in general and Y block stuff. Said he didn't have anything for me but he has a small block that has a 4 speed top loader bolted to it that he might be interested in selling.
I am not worried so much about getting the engine to fit just fine but was wondering if the top loader will require a taller transmission tunnel to fit in my truck which has the 3 speed column shifter.
Any advice or leads if this will require a different transmission tunnel?
What about clutch setup since mine is hydraulic and I am thinking he said the truck this came out of had mechanical linkage??
Old Sep 25, 2025 | 05:45 PM
85e150's Avatar
85e150
Is this a performance car transmission or a top loaded truck transmission?
The car transmission will easily fit where the 3 speed was.
Linkage may be an issue depending on what it came out of.
Measure it out and you will be able to find a solution.
Are you just bringing the transmission?
Old Sep 25, 2025 | 08:42 PM
BCP9875's Avatar
BCP9875
Trailering
Car transmission. From my understanding there were 3 different ones depending on power plant ahead of them. I will be getting the complete rig if I buy it. Engine, bell housing and transmission with linkage.
Old Sep 25, 2025 | 08:47 PM
85e150's Avatar
85e150
Are you going to transplant the whole thing? Or just trans?
Toploader info:
https://www.5speeds.com/toploader.html
https://www.davidkeetoploaders.com/
Old Sep 25, 2025 | 08:51 PM
BCP9875's Avatar
BCP9875
Trailering
Whole thing.
Thanks for the links too. I will check into those.
Old Sep 25, 2025 | 08:53 PM
85e150's Avatar
85e150
OK so you'll see how you are going to have to fabricate or bring over and adapt engine perches for that engine.
Do you know what it is--year and CID?
Old Sep 25, 2025 | 08:58 PM
BCP9875's Avatar
BCP9875
Trailering
Planned on an engine mount kit.
No clue on cubic inches or year yet. He just knew 289, 302 or 351. Got it from an estate recently and hasn't had time to look i to it. I just told him I may be interested of price was right and if it looked like a decent swap. Engine fit, set up isn't of much concern, pretty easy there. Its more of the transmission fit because of height and will I need a different tunnel, and if I can stick w hydraulic clutch or will need to swap to a linkage style clutch.
Old Sep 25, 2025 | 10:16 PM
85e150's Avatar
85e150
My '85 E150 and a lot of others from that era had a hydraulic clutch with an external slave cylinder acting on a fork out the side of the bell.
Some links here to show what I'm talking about.
https://www.ford-trucks.com/forums/1...l#post20816038
Might be same, second link:
https://www.ford-trucks.com/forums/1...l#post18918174
More background:
https://www.ford-trucks.com/forums/1...l#post18271323
You may have to fabricate a mount for the slave to operate the fork.
You could also search out an '84 & up bell that would fit your combination.
I can't find exactly what I was looking for illustration wise but I bet you've got the idea.
Old Sep 25, 2025 | 10:18 PM
85e150's Avatar
85e150
Whaddya know? A picture of the beast:
https://www.ford-trucks.com/forums/1...nder-help.html
Old Sep 26, 2025 | 07:09 PM
BCP9875's Avatar
BCP9875
Trailering
Thank you. I will check that out.
Old Sep 26, 2025 | 09:29 PM
kenny nunez's Avatar
kenny nunez
Small block swap
If the original transmission is still bolted to the engine there is a good chance that the transmission has the wide ratio gear set which is a good combination for the street. Hopefully it also has a Hurst shifter. If the speedometer output hole is on the passenger side then you will need a different gear on the end of the cable. David Kee Toploaders should be able to help you if you have any questions. There is a tag on the case and he can tell you more about it.
Old Sep 27, 2025 | 05:02 AM
BCP9875's Avatar
BCP9875
Trailering
He did say something about the "big" Hurst shifter. Whatever "big" meant.
Guy5556
Apr 12, 2021 07:20 PM
MCD46
May 31, 2014 10:23 PM
Johsens
Jul 19, 2012 11:54 PM
fiftysixfordf250
Oct 16, 2011 09:17 AM
trac292
Apr 29, 2006 08:58 PM
