Sponsored by: Real Truck
AC compressor quite when engine warm?
Old Sep 25, 2025 | 01:47 PM
ScreenSavers's Avatar
ScreenSavers
Trailering
As the title states- AC is great when I start the truck for the first time in the morning (2016 6.7) and after about 15 minutes the AC compressor won't come on anymore. 13.95V at the compressor clutch wiring. Charge is good. Any ideas?
Old Sep 25, 2025 | 02:17 PM
lshort's Avatar
lshort
If you have voltage at the clutch and it is not engaging that sounds like a bad clutch
Old Sep 25, 2025 | 04:47 PM
ScreenSavers
Trailering
Seems to be an intermittent connection at the 2 pin plug to the compressor clutch. I'm gonna replace it. Jiggling it it causing it to work.
Old Sep 25, 2025 | 07:33 PM
Eman85's Avatar
Eman85
You have voltage, do you have ground? When the clutch has voltage and won't engage use the handle of a hammer and tap the clutch face pushing it back towards the pulley. If it engages the clutch has too much gap or the magnet is weak.
Old Sep 25, 2025 | 10:17 PM
ifrythings's Avatar
ifrythings
This is actually very common with electromagnetic clutches that the air gap gets too large, when cold they produce a bit more magnetic force and can pull the clutch in, when they get hot they loose some pulling power and fail to pull the clutch in. Check the gap between the pulley and clutch plate, should be under 0.030 inch.
Anonymous12
Jul 7, 2023 08:06 AM
tsmithco
Feb 13, 2023 05:49 AM
MONAVIERONJON
Jul 21, 2022 07:00 AM
rowekmr
May 22, 2019 12:39 PM
mking_552
Jul 24, 2007 03:07 PM
