460 Dyno results
Old Dec 7, 2003 | 09:47 PM
BigBlockGuru's Avatar
BigBlockGuru
460 Dyno results
Here is the link to the printout *mine is on a CD actually* on my website.
http://groups.msn.com/bayouboard/sho...oto&PhotoID=21
Old Dec 8, 2003 | 07:46 AM
hornet258's Avatar
hornet258
Is that rear wheel horsepower? Good looking truck, and the other pics in the album, well.....alrighty then
Mark
Old Dec 8, 2003 | 11:37 PM
moore89's Avatar
moore89
I have a 460 going into my 67 f100. what combo of parts are you running?
Old Dec 9, 2003 | 10:17 AM
85ford4603/4van's Avatar
85ford4603/4van
that's how they come from factory with 365 horsepower
Old Dec 9, 2003 | 10:40 PM
BigBlockGuru
They had about 100 horsepower less than 365 horsepower from the factory.
Old Dec 11, 2003 | 06:46 PM
bigsnag's Avatar
bigsnag
Can you give us a run down of your engine combo? I'm sure a lot of guys would like to see. Thanks. Oh yeah, nice truck.
Old Dec 11, 2003 | 08:31 PM
fordman428's Avatar
fordman428
yeah i didnt think they cam from the factory with 365 either, i think your right more like 100 hp less, my 390's running 375 hp look at the bottom of my post for specs, oh yes nice looking truck to mine looks just like it but metallic blue.
Old Dec 11, 2003 | 11:41 PM
i_alone's Avatar
i_alone
My 88 EFI engine in My 79 Bronco puts out around 185 hp to the rear wheels, when worked to an equation, it works to around 260-265 hp at the crankshaft,
I have the dyno sheet here if you want to see it
Old Dec 12, 2003 | 12:47 AM
AG4.0's Avatar
AG4.0
I think the high compression 460's of the early 70's had around 350, and when they tuned them to run on unleaded in the mid 70's they dropped to about 220 HP and about 360 ft-lbs. That's about what my Lincoln has, and I think that the trucks were similar.
Old Dec 12, 2003 | 02:47 PM
airharley's Avatar
airharley
What kind of transmission are you running? An auto will have up to 20% hp and TQ loss.
Old Dec 14, 2003 | 09:44 PM
Coogles's Avatar
Coogles
All factory 460- 230hp, 390 tq.
Only 93-97 EFI 460- 245hp,410tq.
They never came with anything different unless a dealer or somethin had them specially modified.
They have always been very low on the HP, but very high on the torque. They have a lot of potential tho
Old Dec 14, 2003 | 09:57 PM
bigsnag's Avatar
bigsnag
Ummm.....no. Actually the pre 72 460's came with 10.5:1 and a decent cam, etc. and were rated at 365 hp at 4600 RPM's and 500 ft. lbs of torque at 2800 RPM's. That's straight from the factory.
Old Dec 14, 2003 | 10:02 PM
AG4.0's Avatar
AG4.0
All through out the 70's the outputs were different, ranging from 200-230 HP after the switch to the low compression heads and backing off the timing. But I also believe that they tested the HP different before 72 using the old SAE Gross instead of Net. showing inflated HP numbers comparatively.
Old Dec 14, 2003 | 10:05 PM
bigsnag's Avatar
bigsnag
Correct. They did switch to net hp rating instead of gross. However, the old high compression 460's made a ton more power than the smog-crippled post 72 models did.
Old Dec 14, 2003 | 11:04 PM
AG4.0's Avatar
AG4.0
Yeah, I didn't mean to make it sound like they didn't get any more power, but it would probably be closer to 295 HP net if you figure 80% of gross vs. net. I got the 80% value from http://neptune.spacebears.com/opine/horsepwr.html but that's just a rough estimate as there are many variables.
