Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
High height jack stands ??
Old Sep 17, 2025 | 10:06 AM
Truck Fun's Avatar
Truck Fun
Question High height jack stands ??
Looking for thoughts on tall jack stands like in the link below. Would be using them around the farm, etc. for any support needed beyond a normal stand. Brands? Quality? Features? Thanks.
https://sunextools.com/products/10-t...ck-stands-pair
Old Sep 19, 2025 | 05:25 AM
Marten's Avatar
Marten
I'm sure there safe but don't understand the use of them. First you need to get the vehicle up that high. Only way I know how is with a hoist. So why not just work under the hoist. They are handy for taking out transmissions when by yourself but you still need to lower it after being unbolted.
Old Sep 19, 2025 | 11:41 AM
PupnDuck's Avatar
PupnDuck
If you're lucky enough to have a lift, they make suspension work much easier. Lift truck; place stands under frame at jacking points then lower the lift SLIGHTLY. Just enough to take all the weight off the suspension.
Old Sep 19, 2025 | 02:47 PM
tjc transport's Avatar
tjc transport
i ain't rite
never used that brand, or that light weight.
i HAVE used semi truck stands rated at 20 ton though.
very stable.
Old Sep 19, 2025 | 07:13 PM
Truck Fun's Avatar
Truck Fun
The intended use would really be for some times around the farm when I need a taller stand rather than stacking up boards under a shorter stand or a hydraulic jack.
Old Sep 20, 2025 | 05:25 AM
tjc transport
i ain't rite
well as with anything, the jack stand used is only as good as the foundation it is sitting on. a level concrete pad? fantastic!
a unlevel field dirt sideroad? the stand will be about as good as stack of cinder blocks with holes facing sideways.
Old Oct 1, 2025 | 03:28 PM
irhunter's Avatar
irhunter
Sounds like they will be good for you. Especially, as earlier poster mentioned, you're using them on flat durable surfaces.
On a related note, I would really like two sets of four heavy-duty saw horses. One set at normal saw-horse height and the other set at half height.
I own countless kind-of-cheesy saw horses...all at the normal height.
Roy
brandon4
Apr 7, 2024 10:51 AM
jspence105
Nov 11, 2012 11:04 AM
Piolet
Jan 14, 2011 01:00 AM
dalfollo
Garage & Workshop
Apr 11, 2004 09:42 PM
PDawson
Garage & Workshop
18
Feb 2, 2004 08:58 AM
