Stake Pocket Tie Downs
Old Sep 17, 2025 | 09:09 AM
pbauer's Avatar
pbauer
4wd Low
I'm curious if anyone has a suggestion for stake pocket threaded tie downs for a 2022 F250.
I've got a ladder rack that I put a boat on and I'd like to use the stake pockets to attach it so I can keep a tonneau cover on. To note, these would need to be robust as I'll have a 350lb boat on a rack system that weights 150lbs itself.
I'm thinking something like this, though I believe these are only for the front pockets. Truck Stake Pocket Tie Downs for Rack (Set of 2)
I know the stake pockets on these 17-22 trucks are a little different than the older ones which has caused some issues in me finding something compatible.
Curious what others are using.
Old Sep 17, 2025 | 09:31 AM
350Recon's Avatar
350Recon
I am not using this but it might work for you.
https://trailerracks.com/products/ei...e-pocket-mount
Old Sep 17, 2025 | 02:03 PM
pbauer's Avatar
pbauer
4wd Low
Thanks - I'll look into it. Ideally something that will sit flush and allow my to screw down into would be preferred but I'm not seeing much out there.
Old Sep 17, 2025 | 04:16 PM
OBS460's Avatar
OBS460
I wouldnt trust these "military grade aluminum" i.e. cheapest bidder thin bed sides to hold a ladder rack with a 350lb boat on it.
Old Sep 17, 2025 | 08:38 PM
pbauer's Avatar
pbauer
4wd Low
So far so good. Went to a bigger boat but no pics.
Clamps hold it down well, just hoping to do something that will allow me to put a bed cover on w/o drilling holes in the top of the rails.
EsteroS
2015 - 2020 F150
Oct 26, 2020 05:27 PM
Mr. Sandman
Mar 2, 2008 09:35 PM
ssj7kids
25
Jul 21, 2007 02:40 PM
Diogenes
May 17, 2004 03:43 PM
