A few months ago I installed front and rear Mag-Hytec diff covers on my 04 F350 PSD. According to the install instructions for the front cover, "there may be some clearance issues". I assumed the issues were during the install procedure and not after the install was complete. Wrong! The front cover, in holding more fluid, sticks out about a 1/4" - 1/2" too far and when the suspension takes a hard hit and compresses, the cover is hit by the tie rod. So what's the fix as I don't think I'm the only one who's had this problem? I read somewhere that the tie rod and drag link need to be bent, but this doesn't sound like a viable or wise option. I could probably grind off the fin on the cover but don't really want to do that either. Any ideas?
I just bought the Mag-Hitec for the rear and was going to order the front too but I thought it was going to rub also. Why do they sell them for the front if they dont fit right?
~Gage~
over the weekend, I installed Mag-Hytec diff cover for the front. Then I discovered it has a major clearance issue with Donahoe Racing steering stabilizer bracket. The bracket would hit the diff cover when turn left. So I went back to the factory diff cover.
I did a little more crawling around under my truck last night. What's hitting is the bracket that bolts onto the frame cross member and bolted to the bracket is what I think is the drag link or stabilizer bar. Regardless, I think I can get the clearance I need by doing a little carving on the bracket and if need be on 2-3 of the fins on the cover or I may be able to heat and bend the bracket where it hits.
Mr. Sandman, are you still having issues with the Mag-Hytec front diff cover?
Im still thinking about getting one for my 2005 Super Duty.
Thanks ~Gage~
I went straight to the source, the mag-hytek doesn't fit if the truck is lifted. I just went for a front diff cover off of yourcover.com and it all worked allright. Of course it's not the work of art that the mag-hytek is, but at least it fits.
