Getting closer
Old Sep 16, 2025 | 06:22 PM
David7's Avatar
David7
4wd Low
Getting closer
I have posted a few threads regarding my brake pedal position in my Ford 67 F1102 Wheel Dr. it is protruding way out past the floor halfway to the seat. I have found out that it has the longer master cylinder shaft attached to the brake arm because some of the 1967 Ford F 100 came with a vacuum booster on the master cylinder. My problem now is I cannot find a part number online anywhere for a vacuum assist booster for this truck. Can anybody help me with a part number?
Old Sep 16, 2025 | 06:56 PM
Green72F250's Avatar
Green72F250
I believe this information was provided by Number Dummy (Ford Truck Enthusiast) member:
C7TZ-2005-C .. P/B Booster 6.75" diameter // Bendix # 2505779 / Obsolete
"1967 F100/350 use one year only brake & clutch pedals, bracket under the dash they suspend from, P/B Boosters, master cylinders, brake pressure differential valves, warning lamp switch, brake lamp switch."
C7TZ-2140-K Master Cylinder - Use with Power Brakes / Obsolete 1967 F100/250 2WD
fordifictor
Oct 15, 2022 06:48 PM
derrickmauk1003
Oct 20, 2014 10:55 PM
jrmwilson
Sep 4, 2014 11:45 AM
BlackLead
Dec 14, 2012 04:40 PM
White73390
Nov 15, 2003 07:55 PM
