512 Code 460
Old Sep 16, 2025 | 11:55 AM
Dr. Driveway's Avatar
Dr. Driveway
512 Code 460
I've had this truck for several years. 1996 F350 7.5 5-spd. This truck has slowly developed a very slight hesitation, and it has very gradually gotten worse. I have the factory wiring book. I eliminated the inertia switch by bypassing it while I was driving. No improvement. It happens with both tanks. Just wondering if anyone else has experience with this trouble code.
Old Sep 16, 2025 | 12:35 PM
rla2005's Avatar
rla2005
Code 512 frequently shows up on this forum. Several recent threads:
https://www.ford-trucks.com/forums/s...rchid=37353832
The most common cause is pulling a battery cable to clear the Stored Codes or some other reason to do so.
Old Sep 18, 2025 | 02:21 PM
Dr. Driveway
Thanks for the one reply. Still figuring it out.
Old Sep 18, 2025 | 02:53 PM
rla2005's Avatar
rla2005
So the question becomes have you ever cleared the Stored Codes by removing a battery cable?
Have you recently removed a battery cable for some reason? Doing so frequently triggers a Code 512 that is stored in memory, aka Stored Codes. It takes 40 or 80 drive cycles for the computer to clear a Stored Code on it's own. You can manually clear the Stored Codes by initiating the KOEO tests and Stored Code display, then removing the STI jumper as the first set of codes are displayed.
Old Sep 19, 2025 | 08:13 AM
manicmechanic007's Avatar
manicmechanic007
There are several reasons a code 512 will set
It's an ignition diagnostic monitor code
A blown fuse KAM will cause the code to repeatedly set
A failing ignition module or processor will cause the code to set
I'd pull the processor out and check the caps, then do a few of the pinpoint tests in the PCED to check the processor power and ground wires
Old Sep 19, 2025 | 08:58 AM
rla2005's Avatar
rla2005
Code 212
I agree
Personally I have never seen that happen, but I suppose it is possible.
I agree it can and we have seen that several times on this forum.
I would wait until the OP responds back on the questions I asked.
Old Sep 20, 2025 | 03:22 PM
Dr. Driveway
I did have the battery disconnected while I did some other work on it. The hesitation was already happening before that, and I got that trouble code then also. I did pull the PCM, and I checked the pins on the connector. All of the hots (KAM good) and grounds were there. I looked in the PCM case, and the board was clean and visually clean on both sides. I had a not-start problem about 4 months ago. I ended up replacing the ICM (with Motorcraft ICM), and the coil. The small shuddering while driving continued. Fuel pressure is a 40@idle rear, and 30@indle front. Hesitation happens on both tanks. I'm going to put the PCM back in and look around some more. Thanks for the replies.
c
Old Sep 20, 2025 | 04:26 PM
Dr. Driveway
I decided to have another look at that PCM. I looked at the capacitors. There are two that have some corrosion near the soldered joints. I'll let you guys look at them and see what you think. One of them feels like it's hanging on with one leg. I'm going to order these three capacitors right now.
Old Sep 20, 2025 | 04:30 PM
rla2005's Avatar
rla2005
Typical leaking capacitor(s) problem plaguing these old trucks. I see signs of a resistor is also compromised from the leakage.
Old Sep 20, 2025 | 04:57 PM
rla2005's Avatar
rla2005
40 PSI at idle is too high. Typical see 30-32 PSI. Strange the rear tank reads higher. What is the pressure under load, both tanks?
Old Sep 22, 2025 | 11:50 AM
Dr. Driveway
I might have those pressures wrong. I did that test several months ago.
For anyone looking for these caps, here is where I found them. I hit the buy it now yesterday. The seller listed the ratings on these - some sellers of these do not (duh). When they get in and I get the PCM in I'll report back.
Ford 80s 90s Computer Premium Capacitors Kit PCM ECU 47uf 16v 10uf 63v | eBay
Old Sep 22, 2025 | 02:03 PM
Truckbuck's Avatar
Truckbuck
I also will mention. When you deal with the ignition system, especially the ICM. Make sure you use heat sink compound on the back of it and not dielectric grease as the module won't be able to cool down properly. Most ICMs are garbage so good on you for getting a motorcraft one. Nice catch on the caps.
Old Sep 23, 2025 | 11:42 AM
Dr. Driveway
I live near a small town where I could not find thermal paste at any parts store, but I went to a cell phone repair place and bought a single application thermal paste syringe, and used it on the PCM.
Old Sep 30, 2025 | 11:29 AM
Dr. Driveway
Got the new capacitors in. Test drove the truck, and the engine seems to run smoother, but not quite all the way. I'm going to be looking into it more.
prolsc
Aug 11, 2023 11:27 AM
crazymut
Mar 22, 2019 10:50 AM
Jim40216
Mar 3, 2017 10:50 AM
johnsmart
13
Jul 27, 2015 10:04 AM
mpmccarthy
Jun 16, 2008 12:30 PM
