6.0 VGT issues
Old Sep 14, 2025 | 08:21 PM
Kylepaddock's Avatar
Kylepaddock
8th Gear
6.0 VGT issues
I have a 2003 F250 with a stock turbo strait pipe. I have a tune on it from PSP Diesel. After long driving on the hwy at 75mph and I get off quickly my truck VGT sould like it opens up fully and sounds like a dodge. It will stay this way and I will roll coal until high RPMS. If I shut off the engine and turn it back on the turbo goes back to normal. I have recently replaced the turbo and it didn't make any difference. Any ideas what it could be? Tune programming?
Old Sep 15, 2025 | 07:39 AM
Baylinerchuck's Avatar
Baylinerchuck
I would recommend getting FORScan or a decent live data reader. You can monitor what the VGT is being commanded. You also need to see what the MAP sensor and EBP are seeing. If you don’t have a reader, check the tubing to the MAP sensor to make sure it doesn’t have any holes and is tight. Check the EBP sensor tube to ensure it’s not caked up and blocked.
Old Sep 15, 2025 | 08:44 PM
Kylepaddock
8th Gear
Ok. I will check those as soon as the truck comes out of the shop. It is getting a front end refresh.
RemingtonCG
Jul 7, 2023 09:04 PM
Hurstspe2015
6.7L Power Stroke Diesel
Jul 29, 2020 12:35 AM
soybeaner
Nov 19, 2011 05:50 PM
mt96
May 8, 2009 08:04 PM
southernfordman
Sep 6, 2004 06:16 AM
