Poor fourm performance
Old Sep 13, 2025 | 11:30 PM
WDXPW's Avatar
WDXPW
Terrible
Old Sep 14, 2025 | 09:30 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
It's working well for me, and was working well for me last night when you posted. Could you elaborate?
Old Sep 14, 2025 | 04:49 PM
WDXPW's Avatar
WDXPW
Yes, I can elaborate. I finally got on myself through using my phone, which isn’t my preferred method, but was the only way I could post pictures on the fourm. I tried to go back to use my normal method of access on the website which is a PC on top of the desk I cannot get on using the PC and using the phone. I’m not sure this is the first time I’m trying to do that if it’s possible to use both with the same ID and the same pass word. It seems the password for my phone won’t work with using access from the desktop PC.Im using the same password and username for both
Old Sep 14, 2025 | 05:09 PM
CathedralCub
FTE Community Team
Without other reports, I suspect it is an issue at the PC or on your PC's path to the Internet.
What company is the provider at this location?
What OS are you using on the PC?
What browser are you using?
Old Sep 14, 2025 | 05:43 PM
Papa Tiger's Avatar
Papa Tiger
Hi WDXPW, try shutting down your WiFi server and restarting it.
It's most likely a server problem downtown.
Download another browser if you wish. Brave or DuckDuckGo. Use it for a few days until yours is back up right again.
I won't say that if you don't like Ai that your browser is screwing with you! But you know?
Old Sep 14, 2025 | 06:36 PM
WDXPW's Avatar
WDXPW
Help hi guys I’m trying to
Download another browser if you wish. Brave or DuckDuckGo. Use if for a few days until yours is back up right again.
so right now I have Comcast as a supplier of my signal Internet signal. I have there router for my connection. I don’t have this issue anywhere else. I’m not an IT guy. It’s quite hard to message you. It’s hard to find this particular message and it’s harder to get to the point where I can respond to you in this way. It’s certainly not easy.
Old Sep 14, 2025 | 08:24 PM
Papa Tiger's Avatar
Papa Tiger
Maybe the below can help you contact them.
Comcast Xfinity Troubleshooting: Ultimate Guide to Fix Issues Fast
Old Sep 15, 2025 | 06:32 AM
charlie g's Avatar
charlie g
FTE Community Team
it's not the site ,more like a PC issue , so yes i'm another with trying a total reboot , turn everything off for a few min's, restart, if using chrome, right upper side the 3 dots, go down to delete browser data , find advanced ,check all the boxes, delete all, reboot
if your using windows,in the search area type history clear browsing history by clicking every box,
many time even with a phone a issue can in many cases be resolved with a simple reboot,
Old Sep 15, 2025 | 10:50 PM
CathedralCub
FTE Community Team
If the issue is continuing, I'm curious what the PC's specs are:
. . . and:
What manufacturer is the PC?
What model is the PC?
What CPU does the PC have?
How much memory does the PC have?
Old Sep 16, 2025 | 04:24 AM
charlie g's Avatar
charlie g
FTE Community Team
and if running windows 11 did the issue start after the last 2 monthly updates ? ask as MS has caused issues with the last updates,one caused a black screen , another in a case i had, it told me a PC running 11 pro was not capable of running 11 due to CPU and tpm issues, temp fix was to delete both updates, what programs or extensions has he recently added? what issue in his pc is blocking his logging into fte
whatever the issue, is not from the site, it is totally on his end
Old Sep 17, 2025 | 03:45 PM
charlie g's Avatar
charlie g
FTE Community Team
PAUL
if you can read this, the issue is on your end, if you have any popup blockers installed on your windows 11 PC, disable them, try using the new duckduckgo browser. or librewolf,
Old Sep 17, 2025 | 05:02 PM
Papa Tiger's Avatar
Papa Tiger
I'm going to guess his hard drive is failing him. Knowing which type of Solid-State drive, it would give him choices.
Knowing he is not a computer I T would mean Taking it to be repaired. Running the FKey tests & System with startup could lead to the knowledge needed.
The Dell Desktop 11 pro models will accept 2 different styles of internal hard drives well above 1 T.
Then one can also run the reset function with system.
Old Sep 17, 2025 | 10:26 PM
CathedralCub
FTE Community Team
I agree, it's not the site.
Troubleshooting @WDXPW's PC from here, with what little information we currently have, would likely prove futile.
I'm curious if @WDXPW is still having issues today, and if other sites are working normally at the same time.
Hopefully he comes back and updates us!
Old Sep 18, 2025 | 05:42 AM
charlie g's Avatar
charlie g
FTE Community Team
not FTE related
case closed, thread closed
Mike-at-SolerEngr
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 5, 2024 10:39 AM
