HEATER
Old Sep 9, 2025 | 06:27 AM
ADELEANDRE's Avatar
ADELEANDRE
HEATER
I have a question about how the heater works.
On each side of the dashboard, there are "pull tabs" for the hatches next to the doors.
The pull tab for the fan switch must be on a hatch on the heater core ?
Two other pull tabs are below the car radio, one of which must open and close the coolant inlet. What does the other one next to it do ? Does it open another hatch on the heater core ?
Old Sep 9, 2025 | 09:10 AM
TA455HO's Avatar
TA455HO
Lead Gopher
There were two types of heaters - recirculating and fresh air. The drawing you show is for the fresh air. Correct, the one cable operates the valve (18459) on the passenger's fender to open and close the hot radiator coolant circulating through the heater core or not circulating. The other cable opens and closes the second flap inside of the fiberglass plenum. The tip of the cable slides over the lever pointed to by the blue arrow and the cable sheathing is held in place by the bracket pointed to by the red arrow - along with the small clamp (378892-S) and screw (41036-S)
Old Sep 9, 2025 | 11:54 AM
ADELEANDRE's Avatar
ADELEANDRE
ah ok I hadn't seen this latch, thank you very much, every time you are a great help to me
Old Sep 11, 2025 | 09:58 AM
drm4633's Avatar
drm4633
An actual pic for reference
grip1968
Mar 22, 2020 10:46 AM
Cdy1
1997 - 2003 F150
Oct 7, 2010 08:54 AM
73Riviera
Sep 8, 2006 02:08 PM
holiday187
General Automotive Discussion
Sep 7, 2004 10:33 PM
