Low Break Pedal
Old Sep 7, 2025 | 06:23 PM
SMarquez's Avatar
SMarquez
Low Break Pedal
22 F250 7.3l CCSB 46,696 mi., near 15,000 towing miles.
It seems like my brake pedal is low. Still stops fine just seems to use up a little more travel. My front brake pads look to have about 8mm of thickness left. Fluid looks low in the reservoir. Haven't looked but does anyone know the OE pad thickness? Maybe it's just time for brakes. Your input appreciated.
Old Sep 7, 2025 | 07:13 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Only 8mm?
That's getting close to time to change.
Also, according to the owner's manual, 3 years is time to flush the brake fluid, and you're past that.
Old Sep 8, 2025 | 02:09 AM
SMarquez's Avatar
SMarquez
Thanks
Old Sep 8, 2025 | 06:43 AM
HorizontalHunter's Avatar
HorizontalHunter
To add to @Ltngdrvr said; under normal operation as the brake pads get thinner the piston moves out of the caliper increasing the fluid space in the caliper so the fluid level in the master cylinder goes down.when the brakes are done and the piston is pushed back in the caliper the fluid will return to the master cylinder.
As was said above, it’s about time to do the brakes and past due time to flush the fluid.
Bob
Old Sep 8, 2025 | 06:57 AM
scraprat's Avatar
scraprat
Top Answer: 5
@ 45k miles and a 1/3 of it towing and visually seen low fluid with soft pedal. To me that screams brake pads. Pads are cheap and easy to replace.
Old Sep 8, 2025 | 02:33 PM
1olddogtwo's Avatar
1olddogtwo
Factory brakes are about 12 mm, and your @ 8, I would think you have plenty of life left. A majority of my trucks will go 100,000 mi before needing brakes.
A low brake pedal is not a result of low brake pads.
ggenovez
May 9, 2025 04:13 PM
MixWizard
Mar 27, 2023 02:23 PM
ericg70
2011 - 2019 Explorer
Oct 6, 2016 05:03 PM
texastech_diesel
Nov 23, 2009 10:31 PM
powerstroke6ltr
Jan 4, 2007 09:21 PM
