Parasitic draw question.
Old Sep 6, 2025 | 04:49 PM
Hootr's Avatar
Hootr
Was doing some regular maintenance on the truck and decided to do a parasitic draw test just to see where it was at.
When the truck was awake, the draw was 0.179. When the truck went to sleep it dropped to 0.009. Is that normal?
Just seemed low to me...I was expecting between 15-30ma.
Old Sep 6, 2025 | 06:57 PM
John in OkieLand's Avatar
John in OkieLand
that is what it should be, higher values indicate something is pulling more current than it should.
with your 0.009 value, the truck could set for six months and still have a battery good enough to start it up.
Mine?
nope, it has enough draw to pull the batteries down in 3 weeks.
so, I keep it on a battery tender.
got tired of fooling with it, 2 years ago, then a family crisis intervened and have not got back to the truck again.
Old Sep 7, 2025 | 07:20 AM
danskool's Avatar
danskool
Go Bills !
Ha ha.
mine is out sitting in front of the camper , looks likes Christmas if you peek in the windows . All the charging cords, tire pressure monitor charger, android charger. Battery voltage thingy, dash camera running. Mx+ dongle light . Will sit for a few days . I dont worry about it .
when not out , parked at home. I unplug everything. It will sit for a couple weeks .
six months in unheated shop , I open my stabs.
Those are low numbers , wish I had that.
Old Sep 7, 2025 | 10:40 AM
Hootr's Avatar
Hootr
Thanks for the replies, I pretty much disconnected everything when I did the test.
I wasn't expecting to be that low, but glad it is.
Old Sep 7, 2025 | 11:13 AM
Texmax's Avatar
Texmax
Might want to check the Body control module or GEM, whatever you wanna call it, Mine was shorted to ground on my Excursion. My battery draw would kill the battery if I didn't drive it for a week or two. I put disconnects on both batteries as a patch until I figured out the real issue. BCM/GEM aren't easy to find and they go by VIN to match. Good luck.
01 7.3 EX
Swamps 175/146.Swamps HYDRA tunes, stg 2 hpop. pusher intake. Mishimoto intercooler. KC turbo Gen3 stg 1. Built Transmission. 4" Diamond eye Exh Tru cool trans cooler, de rale trans pan,X code front springs/ 43-1263 hd rear springs,driveshaft disconnect, ultra hunter 18x9 -12 wheels, 35x12.5 bfg ko2, Ranch hand/ bodyguard bumpers, S&B airbox,Spal Fans on radiator and trans cooler, MECHMAN 320 amp Alt.
jlillie
Feb 2, 2016 03:34 PM
hrc200x
30
Mar 11, 2011 07:47 PM
TinyWonder
Nov 2, 2010 02:00 PM
Dyllan78
Aug 19, 2010 02:44 PM
guitarpicr
Nov 4, 2007 08:42 PM
