Engine swap
Old Sep 2, 2025 | 09:14 PM
TheBirdMan's Avatar
TheBirdMan
4wd High
Post Engine swap
I have a 93 Lightning, truck is not numbers matching but is a real R code. I am in need of a full vehicle wiring diagram. I'm working on getting the parts and diagrams together for putting a 98 Lincoln mark VIII 4.6 DOHC with 4R70W
Old Sep 3, 2025 | 12:42 AM
wwhite's Avatar
wwhite
Deleted…..
Old Sep 3, 2025 | 01:00 AM
85e150's Avatar
85e150
Do you have the entire harness, computer, ignition, dash etc from the Lincoln?
Old Sep 3, 2025 | 05:52 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Why? From what I see, you are going to be installing an engine with less torque than the 351W.
Old Sep 3, 2025 | 07:16 AM
Motohowie's Avatar
Motohowie
I’m assuming the Lincoln is what you have and you want a daily driver out of the Lightning so this doesn’t help you with your problem. But I can tell you from experience you’ll be underwhelmed by the 4.6/4R70W in the truck for the trouble you’ll go through making the swap because of the ~700 pound weight difference in the two vehicles. Mine was the truck performance equivalent of an 80s 4 cylinder Mustang. As a commuter or grocery getter it will do just fine.
Old Sep 3, 2025 | 07:22 AM
rla2005's Avatar
rla2005
This is a good place to start: Ford: 1993: F 150 2WD Pickup V8-351 5.8L Lightning
I am not sure anyone has full size vehicle diagrams these days.
Old Sep 3, 2025 | 07:58 AM
wwhite's Avatar
wwhite
Sell your truck for double an F150, get another F150 and body swap it to the lincoln.
What does numbers matching mean?
R - code 351w, flat tappet cam, GT40 heads and intake.
Interior custom SVT LIghtning upholstery.
Custom suspension
Your better off stroking the 351w, and fixing what you got.
Oh wait!, you don't know what you got, other wise you wouldn't have even thought about this post!
Old Sep 3, 2025 | 08:34 AM
My4Fordtrucks
I agree with doing that to a regular F-150 but not a Lightning. For me, that would kill the value of the Lightning. I’m pretty sure the Lincoln is a unibody so…
Old Sep 3, 2025 | 09:29 AM
wwhite's Avatar
wwhite
It is a frame, same as a 'crown vic swap' for slick 60s.
Old Sep 3, 2025 | 09:31 AM
wwhite's Avatar
wwhite
Probably never hear from @TheBirdMan again, new poster, hasn't logged in again.
@TheBirdMan I'd trade you my 1994 Flareside for your Lightning? Where you located?
Old Sep 3, 2025 | 12:23 PM
Scndsin's Avatar
Scndsin
South Carolina
Old Sep 3, 2025 | 08:12 PM
TheBirdMan's Avatar
TheBirdMan
4wd High
Yes, I have two complete 98 Mark VIII's both running, but no titles
Old Sep 3, 2025 | 08:19 PM
TheBirdMan's Avatar
TheBirdMan
4wd High
Wrong, the Mark VIII's thunderbirds, and cougars are MN-12s, a unibody, not a full frame like the crown vic's
Old Sep 3, 2025 | 08:51 PM
TheBirdMan's Avatar
TheBirdMan
4wd High
Thank you
Old Sep 3, 2025 | 09:10 PM
wwhite's Avatar
wwhite
I know as much about 98 mk8 as you do about lightning’s!
