'79 Missing, Flooding?
Old Dec 7, 2003 | 02:51 PM
Kenny's Avatar
Kenny
Greetings,
I'm currently experiencing a few problems with my '79. It may be more than one problem happening at once, and I'm trying to solve by process of elimination. I need some expert opinions ON this. Here's what I have.......
1979 F-150 4x4, 351M, 2bbl carb, C-6 Auto.
Here's the symptoms.
FIRST PROBLEM.....
Long after the truck warms up to operating temperature (about 1+ hours of driving), the truck starts to run like it is flooding or missing. It only does this while in gear, and usually happens from take off until it shifts to 3rd. The problem is it only happens sometimes.
If I drop the truck into neutral, it instantly runs smooth and does not feel like it is flooding or missing. In other words, I don't have to floor the accelorator to clear it out. If I stop and shut the truck off, I can start back up and it will run fine for a while. When it acts up, it seems worse under load (upgrade, pushing snow, etc.). I just had a rebuilt carb installed, but to no avail.
Any ideas?
My first thoughts would be .......
replace fuel filter
bad modulator valve?
Vaccum problem?
Thanks in advance for any help, sugguestions, or opinions.
Old Dec 7, 2003 | 09:19 PM
chris69's Avatar
chris69
my 78 f-150 had the same flooding problem. we put a new carb, plugs ang plug wires on and it ran awesome
Old Dec 9, 2003 | 01:13 AM
Torque1st's Avatar
Torque1st
Posting Legend
Have your ignition system modules tested.
Old Dec 9, 2003 | 04:19 AM
Jerrybo66's Avatar
Jerrybo66
Are you sure it's flooding? It could be running short of fuel when under a load . I would check the fuel filters. I had the same problem in my Jeep..
Old Dec 9, 2003 | 08:43 AM
Kenny's Avatar
Kenny
Thanks for the replies.
I guess I shouldn't have used the word "flooding" to describe the symptoms. I don't think it is flooding at all since I just had a factory rebuilt carb installed.
It's probably more like it's not getting gas, or maybe losing spark.
Old Dec 11, 2003 | 07:14 PM
Kenny's Avatar
Kenny
Hi all, thanks for the replies. Just wanted to bring closure to this thread.
Turns out two of my spark plug wires were rubbing on the steering shaft u-joint, and wore right through to the core. They must have been only arcing when the wheel was in a certain spot. The wires were replaced earlier this year, so I kind of overlooked the obvious.
Also, the vaccum "tree" on the back of the carb was loose, the vaccum hose to the trans was kinked, and the modulator valve on the trans went bad.
Seems to be running well now (knock on wood).
NW 150
37
Apr 22, 2011 12:10 AM
NW 150
19
Mar 25, 2011 08:43 AM
nothercrash
Dec 22, 2010 10:12 PM
1985ColumbusF150
Oct 17, 2004 10:03 PM
