Luckily (or unluckily?) it was frozen prior to towing it. I think just rusty linkage, but it was/is in 2 high. Towed it about 15 miles. Got up to 60mph for a few minutes, but most of it was 30mph or less. The engine does run, but I haven’t tried putting it in gear yet. I’ve been revamping the fuel lines/pump/tank, so the drivetrain was the next problem.
I thought I had added that info…I’ll figure it out eventually. It’s a 1985 f250 with a 351w. It’s a manual 4x4. I’ll try to find out the transfer case specifics later today.
The transmission is in neutral and so is the transfer case. Front drive shaft spins freely by hand, but when I try to move the rear one it feels stuck. When i turn the rear wheels (jacked off the ground) they want to spin the drive shaft, but it’s stuck.
With the trans in neutral and the rear wheels off the ground: cannot get the either rear wheel to turn.
Originally Posted by jgreco
I suspected locked breaks, but I've since replaced all four tires and the front two (while both off the ground) spin freely. The rear two (also both off the ground) simply dont. I honestly dont know if they moved together because I couldn't rotate the wheel much at all. I can see it moving the drive shaft, but then something in the transfer case is stopping it.
I have no idea how replacing the tires would fixed free up a locked brake. You still cannot turn the rear wheels.
I disconnected the drive shaft from the rear differential and it’s still locked. When I try to turn it by and it rotates a fraction of an inch back and forth, but makes a weird clacking noise in the transfer case.
With the driveshaft disconnected from the diff, you say you can move the shaft a little bit but there is a “clacking “ noise. Ok, that could be gear lash which is normal. How hard are you trying to turn the driveshaft because it won’t be easy since you might be trying to turn the transfer case and transmission. Can you now turn the rear wheels? You did not say.
I have found if I use my phone to post or make a change the sig for some reason dose not show up.
Dave ----
Sorry for not being more clear. When I replaced all the tires (dated from 2001) I tried turning the wheels and the fronts spun, but the rears did not. There was enough play though that I was confident the issue wasn’t locked brakes. I’ll be checking out the rear output bearing tomorrow afternoon. The magic of the internet has directed me towards examining that.
If you towed it home it had to turn then no?
Undo the rear drive shaft from the rear pinion, watch that the ujoint caps dont fall off. I wrap a shop rag around the joint and use duct tape to hold them in place.
You should be able strap it up with out the need to remove it from the transfer case.
With the shaft removed and the rear wheels off the ground see if you can turn the pinion yoke and report back.
Oh you should also be able to turn the drive with the transfer case out of gear and / or the trans out of gear.
Dave ----
How can you say that the rear brakes are not what is keeping the wheels from turning?
Restating what I’ve already said. They were rotating on the tow home (obviously), and then the truck wouldn’t roll once back on the ground. Hence why I initially thought front brake issue since those were off the ground while it was able to be moved. I’ve disconnected the drive shaft from the rear differential and it’s still not rotating, thus the problem is in the transfer case.
Just to clarify, do you mean transfer case behind the transmission or the differential (pumpkin in the middle of the axle)? If the drive shaft is disconnected, the transfer case can no longer prevent the wheels from turning. They are two different things, both of which your 4WD truck has that could be an issue, so we need to be clear on what you are referring to in order to focus on the proper problem.
I’m referring to the transfer case behind the transmission. The drive shaft has been disconnected from the pumpkin, but is still not rotating, so whatever is stopping the driveshaft is in the transfer case. Without tearing into it, I’m hoping someone here has some ideas on what it could be.
