Weird Boost Pressure Fluctuations
Old Aug 25, 2025 | 10:25 AM
Great Danes's Avatar
Great Danes
So I had my trailer hooked up and we were driving on the highway at normal speeds of 60-70mph, no major hills or anything, just generally flat. At one point about 100 miles into the trip I accelerated slightly as there was an incline on the road. The truck made an odd sound kinda like a loud sucking noise but no loss of power or anything but I noticed the boost pressure needle was buried to the right for a split second. I looked at my phone as I have the Torque app installed and it showed my boost pressure spiked to 39psi. Everything returned to normal and the whole episode lasted no more than 2-3 seconds. About 45 mins later it happened again, but we were on the flat just cruising when the truck seemed like it was hesitating a bit and the boost guage was swinging all over the place despite no throttle input changes and it had spiked again to 39psi.
I pulled into a rest area let the truck idle down to cool off and then shut it down for about 10 mins while we got some coffees. Restarted the truck and drove off and nothing further on the balance of the trip (another 300 miles) or on the return a few days later.
So I'm wondering if this was a random fluke kinda thing or a sign of things to come? Has anyone else experienced similar or can someone give me an idea of some things to check out to be proactive?
Cheers,
Old Aug 25, 2025 | 08:45 PM
SMSTX's Avatar
SMSTX
Check your CAC tubes for splits or silicone/clips no longer holding
Old Aug 26, 2025 | 08:43 AM
speakerfritz's Avatar
speakerfritz
aside from mentioned
sensor gremlins
or a puddle of oil in your intercooler that you engine gulped down and did an oil fart.
Old Aug 26, 2025 | 09:17 AM
1olddogtwo's Avatar
1olddogtwo
Sticking vanes will cause a over boost, surprised no code was set.
Old Aug 26, 2025 | 10:09 AM
Great Danes
CAC tubes are all aftermarket upgrades, so no possibility of splits and all connection boots are/were tight
sensor gremlins
Where is the sensor located and is it easily checked? I will pull my CAC pipes form the intercooler to see what the oil situation looks like.
I was surprised as well and even scanned it after the trip and no codes showed up. Are sticking vanes an indication of impending failure?
Teds
Jul 22, 2012 03:14 AM
hucka1a
Oct 11, 2008 11:58 PM
Rodeohauler300
Apr 2, 2007 02:24 PM
MikeSDK
Jul 15, 2006 09:27 PM
jeepnford
Apr 28, 2002 09:13 AM
