Starting issues
Old Aug 24, 2025 | 10:07 PM
Penguin150's Avatar
Penguin150
1st Gear
Starting issues
Hi,
Just inherited a 1989 F-150 5 liter and having issues getting it to start. (I has been barn stored for about 3 years and not started during that time). I replaced the battery, and the alternator was replaced recently as well. The problem is that you turn the key and hear a click and it shows low battery (about 8 volts). But if you do this say no more that 5 times, it will start up and run like a top. But the next time you start it, it may do the same thing. Is this a known issue with the older F-150s? The truck is an amazing shape and low miles so really want to get her running great if I can.
Thanks for any suggestions!
Old Aug 25, 2025 | 04:24 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Penguin150
…The problem is that you turn the key and hear a click and it shows low battery (about 8 volts). But if you do this say no more that 5 times, it will start up and run like a top. But the next time you start it, it may do the same thing. Is this a known issue with the older F-150s?
Condtion of the battery cables and connections? Shows 8V on the gauge? What is the battery voltage at the battery? Not a common “known” problem. You have something going on with that particular truck.
Old Aug 25, 2025 | 04:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds to me like bad cables, cable connections, or bad grounds.
carlmeson
2009 - 2014 F150
May 25, 2024 05:53 PM
bluescrew
16
Apr 8, 2010 03:13 PM
generalgeorge
Nov 23, 2009 08:35 PM
BlackFX4Screw
2004 - 2008 F150
Dec 21, 2008 08:52 PM
4.2Lbeast
3.8 & 4.2L V6
Mar 27, 2005 08:08 PM
