Fuel gauge problems
Old Aug 24, 2025 | 02:54 PM
meanstreak02's Avatar
meanstreak02
4th Gear
Fuel gauge problems
I’m having troubles with my fuel grade on my 79 f150. I pulled the wire connector off of the sending unit and basically shorted the connector. This made the garage move so I figured the unit was bad. I bought a new unit and installed it. It was working fine and now it’s not again. Did the shorting test and it worked but when is all hooked up, the garage doesn’t move. Oh yeah the tank is at least half full. Any advice would be greatly appreciated.
Old Aug 24, 2025 | 07:09 PM
meangreen92's Avatar
meangreen92
Is it just one wire to the sender? If so, then it has to be positive. That means that if your tank isn't grounded to the chassis, (because of insulated straps) that the sender won't work. Just a shot-in-the-dark theory.
Any anomalies from your Temp and Oil gauges?
Old Aug 24, 2025 | 07:19 PM
dlburch's Avatar
dlburch
three things...your new sender is bad, your new sender doesn't have a good ground or the float is full of gas and can't "float"
Old Aug 25, 2025 | 08:42 AM
meanstreak02
4th Gear
There’s actually two wires coming to the tank. I assume positive and ground. When I jump the two the gauge moves.
Old Aug 25, 2025 | 09:02 AM
tbear853's Avatar
tbear853
Had a '84 Subaru act like that, was easy to get to sender, pulled it, cleaned it and added some tension to wiper (bend the arm), 100% fixed.
Old Aug 25, 2025 | 03:43 PM
meangreen92
The gauge should peg on Full, when you ground the wire.
1977_f10028
Apr 26, 2019 01:04 PM
rdpickett406
1978 - 1996 Big Bronco
Jan 23, 2015 08:29 PM
Dimmick24
Nov 23, 2013 02:46 PM
undertakerman
Jul 25, 2010 02:30 PM
SideWinder4.9l
Dec 30, 2009 05:40 AM
