351's
Old Dec 7, 2003 | 02:18 PM
RedneckRanger's Avatar
RedneckRanger
351's
What is the difference between the 351 windsor and cleveland engine? me n my buddy were talkin bout it but came to a block. no pun intended. what were the applications for them engines too?
Old Dec 8, 2003 | 08:24 AM
bronco351's Avatar
bronco351
Really the only difference was the windsor was fuel injected and the cleveland was carberated!! Someone correct me if I;m wrong!!
Old Dec 8, 2003 | 06:11 PM
jwtaylor's Avatar
jwtaylor
The only similarities are the small block bellhousing bolt pattern and 4" bore. Otherwise they are completely different. The heads are not a direct swap, you can modify the coolant passages to make them work, otherwise, they are not similar. later
Old Dec 10, 2003 | 07:01 PM
mustange70's Avatar
mustange70
the windsor's a torque motor (made for working in trucks and lots of power dorn low) and the cleveland and its huge heads make a lot of power in the top end (designed to go fast when built right, the cleveland not the 351m/400, is a car motor and isn't the greatest for a truck motor-depending on what you use the vehicle for)
Shernius
55
Jul 27, 2020 04:02 PM
Shernius
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 11, 2004 09:12 PM
91f2504x4
Dec 25, 2003 03:58 PM
iggy1982
Aug 13, 2003 09:54 PM
tellico racing
1978 - 1996 Big Bronco
Nov 3, 2002 12:53 PM
