Rear lock actuator??
Old Aug 23, 2025 | 02:14 PM
RUSTEZE's Avatar
RUSTEZE
Got an 89 crew cab f350, and I’ve replaced the RR door lock actuator, but it doesn’t seem strong enough to move the latch consistently (usually isn’t strong enough to even try). Bought it off of amazon. Was wondering where others have found a good strong replacement that didn’t break the bank? The one from oreillys is like $200 or something if I remember right, and if that’s what it needs then that door just won’t lock 🤣
Old Aug 24, 2025 | 07:34 AM
manicmechanic007's Avatar
manicmechanic007
How hard is it to unlock with the key?
I would suspect the cheap Amazon actuator
Seldom do I see lock mechanisms get sticky or gummed up
I would pull the panel back off, disconnect the actuator and see how hard it is to move the lock linkage in the latch
The junkyard is where to get a good working actuator, most last 40 years or more
Old Aug 24, 2025 | 02:30 PM
RUSTEZE's Avatar
RUSTEZE
the rear doors don’t have a key lock, just the rod and the actuator. The rod is kinda stiff to move, but I don’t think it’s stiff enough to cause this. Could be wrong, though. I have already tried cleaning out the door latch/lock mechanism and lubricated thoroughly
Old Aug 24, 2025 | 10:25 PM
manicmechanic007
Forgot you were working on the rear door
I think I would replace the actuator again
See if they will warranty it
Greg In Houston
Jul 23, 2025 05:11 PM
bbender85
2015 - 2020 F150
Sep 13, 2022 07:00 AM
Bryan Sternberg
Apr 13, 2018 07:16 AM
justin90gsx
May 15, 2015 05:51 AM
andym
Apr 13, 2015 07:36 AM
