4WD problem
Old Dec 7, 2003 | 01:43 PM
jimb206's Avatar
jimb206
4WD problem
Yesterday when putting the shift on the fly 4WD **** into 4hi the truck went into 4WD but with a big thump. I drove quite a bit yesterday and the truck ran fine . Today when I put it into 4WD it stayed in 2WD. The 4X4 light doesn't come on and there is no power going to the front wheels. Do you think this is an expensive problem as in taking the drivetrain apart or could it be just the switch or a relay of a fuse? Hoepfully a fuse but some how I doubt it.
Jim
Old Dec 7, 2003 | 06:25 PM
clean79150's Avatar
clean79150
Big thumps are usually a bad thing. ...ouch
What kind of transmission and transfer case is it, and what year truck?
Old Dec 7, 2003 | 06:59 PM
78fordman's Avatar
78fordman
Were you moving when you put it in 4x4? I would check the vaccum pump, otherwise try pulling the codes, see if anything comes up.
Old Dec 7, 2003 | 07:26 PM
jimb206's Avatar
jimb206
It's a 2000 F350 V 10 4 Speed Auto. I don't know what transfer case it is.
And yes I was moving when I put it in 4WD.
Thanks
JIm
guessrow
2004 - 2008 F150
Jul 26, 2014 10:19 PM
Lake Rat Jim
Apr 25, 2012 05:45 AM
BRONC-OH
Bronco II
Dec 1, 2011 10:17 PM
jck_strw
Mar 7, 2008 05:51 PM
paulcalif
Mar 17, 2006 01:11 PM
