random power loss
Old Aug 20, 2025 | 08:47 PM
Bill97's Avatar
Bill97
random power loss
Hi Team - I have a new to me 78 Ranger with the inline 6 4 speed. love cruising around town with it. Few days ago, it started to stumble in 4th gear. it will die out and come back, die out and come back. it will do that repeatedly until you slow down or stop, then will run normal again for a good while before it repeats the loss of power again. Obviously it's fuel related. I installed a new tank and lines last month. has a new fuel filter so I can rule out junk in the tank and lines. I ordered a fuel pressure gauge, and a new mechanical pump. just want to make sure I'm on the right path. if not that, it would have to be carb, but it feels like a fuel pump issue to me.
Old Aug 20, 2025 | 09:10 PM
Bushbased's Avatar
Bushbased
It may' be the coil, an old weak coil will often allow the engine to start and be driven for a while until it heats up and under load low revs in 4th gear as you are finding break down, voltage drop as load on engine increases, it may rev up ok in neutral but when more voltage is required ie loading it starves the distributor's ability to deliver enough spark, much like fuel starvation in effect.
Just try another coil and maybe check the HV coil lead to distributor.
trust this helps
regards Ross
Old Aug 20, 2025 | 09:12 PM
Bushbased's Avatar
Bushbased
I just thought of another possibility, a worn ignition switch can cause intermittent power failure to the coil and is not an uncommon problem.
Old Aug 20, 2025 | 10:24 PM
JimsRebel's Avatar
JimsRebel
Here's info on how the switch can fail.
You can monitor the coil positive voltage while driving, to see if anything changes when it dies. If nothing changes it's fuel related.
Old Aug 21, 2025 | 08:31 AM
440 sixpack's Avatar
440 sixpack
If you can get it to want to die , shut it off and cost over to the side of the road. pull the air cleaner lid and see if it squirts fuel out of the accelerator pump. this will tell you if it's fuel or spark.
most likely it's the carburetor I'd just go there now.
Old Aug 21, 2025 | 08:53 AM
Bill97's Avatar
Bill97
Thank you team. I have the pump and parts coming already. I'll order coil too, if those dont fix, I'll look into the switch. Appreciate the help. it's been a while since I've been carbonated. but at least everything is easy to get to.
Old Aug 21, 2025 | 03:54 PM
dlburch's Avatar
dlburch
did the problem occur prior to swapping the tank?
when the problem occurs, remove the gas cap and see if there is a vacuum built up in the tank.
Old Aug 21, 2025 | 08:32 PM
440 sixpack
Good suggestion.
Malachai Styxx
15
Nov 20, 2024 04:44 PM
fatazz350
Oct 16, 2021 09:23 PM
rhino123
Aug 9, 2016 08:35 PM
DBAPilotDad
31
Jun 24, 2008 09:14 PM
LeonR
Bronco II
Mar 16, 2004 05:04 AM
