Sponsored by: Real Truck
CACT12 Reading
Old Aug 27, 2025 | 10:17 AM
Overkill2's Avatar
Overkill2
Originally Posted by ken235
Thank you Sir!
I'll try to remember that about Rock Auto.
We have AutoZone, O'Reillys, Advance Auto, which are local, and NAPA which 25 miles away.
I'm thinking this guy is going to be my go to mechanic when I need one.
Have to get things in order for the trip to AZ, our reunion with the 35th Infantry Regiment Association in two weeks.
We have all those as well but for parts, but especially rotors and pads even with shipping, it's a lot cheaper buying through Rock Auto. I have bought exhaust kits for an 11 Escape and a 15 Fusion that are cheaper than what you can get through the dealer and probably the parts stores. My wife's 11 Escape was totaled and still have the rear muffler in the garage as I needed just the resonator.
Have a safe trip and enjoy Ken.
Old Aug 27, 2025 | 09:20 PM
ken235's Avatar
ken235
The mechanic changed out the sensor. Looked at it via his scanner. He shows it is good now.
But I still a have problem with the PID on my iPhone where it shows sensor CACT12, -40 and a voltage 2.52 or less some times.
He said the voltage showed bad on the sensor he changed before he changed it.
And after he changed it the temp was 101deg F and the voltage was normal. I don't recall the exact voltage he had said. I was not watching his scanner at the time.
I'm going back tomorrow to get him to run through that while I watch.
And take a photo of the name of the sensor on his scanner that he will be looking at concerning the charge air cooler.
My iPhone is F'd up on those charge air sensors. That's on two different iPhones.
Maybe I should reinstall the app.
I tried, but I'm not very swift on viewing the CAC PID's with Forscan and the laptop.
I didn't know which group they were in.
Old Aug 28, 2025 | 08:55 AM
Overkill2's Avatar
Overkill2
I believe my iDash can read the IAT sensor but not sure of the temp sensor in the MAF sensor. Will have to check on that.
Old Aug 28, 2025 | 09:08 PM
ken235's Avatar
ken235
I would like to look at it via the laptop with Forscan to see if it is different from what the PID on my iPhone shows.
But I'm not familiar on how to find the PIDs with Forscan.
Also, the high priced professional scanner that the mechanic used, displays different information than what Forscan does.
Old Sep 5, 2025 | 08:10 PM
Overkill2's Avatar
Overkill2
Okay Ken... the Banks iDash monitors MAT (manifold air temp) which I believe is the built in temp sensor in the MAF sensor.
Banks also has a PID for the IAT sensor, the one you changed out, called IAT1/1 (Bank 1 Sensor 1).
I worked a sidejob after work today. Got in the truck, started it and played around to find those two PIDs listed under the Temperature category... I have a second screen set up that I change when I need to and monitor stuff.
Here's the two temps listed of MAT and IAT1/1 at start-up.
On the I90 Thruway (highway) driving at 62 on cruise.
Came down more...
On the expressway now at 65 mph.
Ambient air temp
Doing 70 and still on expressway..
It was wild that once off the expressway and shooting up the hills going home, when I stepped on the throttle, you could see the MAT go up which makes sense because it's getting hotter under the hood from the engine, turbo and exhaust gas temps... but the IAT remained relatively the same...
Just thought I'd post this up for you..
Old Sep 9, 2025 | 10:01 PM
ken235's Avatar
ken235
Thanks for showing your gauges.
The mechanic's scanner description was Charge Air Cooler temperature sensor circuit high (Bank 1)
Nothing is different on the sensors that I was monitoring.
I brought the thermistor home to check it out with my fluke VOM.
It is a good sensor. It is NTC. Negative temperature coefficient thermistor. Temp goes up resistance goes down, and vise versa.
Old Sep 10, 2025 | 08:16 AM
Overkill2's Avatar
Overkill2
No problem. Hope you had a good reunion trip...
Old Sep 10, 2025 | 11:28 PM
ken235's Avatar
ken235
I am on the second day of the trip.
Today we arrived at our destination in Chandler, AZ after a 1,300 mile trip from the east side of TX.
I don't want to jinx it, but the truck did good.
The distance between regen milage got better during the trip. And got 19.2 mpg driving 70 and 75.
I'm used to seeing 14.5 mpg.
Other than that,
It is HOT here.
Old Sep 11, 2025 | 09:38 AM
Overkill2's Avatar
Overkill2
Other than that,
It is HOT here.
Getting that kind of mileage means flat lands...
Good to hear truck is doing well...
Remember Ken, its a dry heat...
Old Sep 21, 2025 | 10:14 PM
ken235's Avatar
ken235
You're right about that. Like an oven.
From Chanler, AZ on Sept. 13th and spending one day in each Park, Sequoia National Park, to Yosemite Nat'l Park, to Yellow Stone Nat'l Park to Mount Rushmore today Sept. 21th. Tomorrow, the Badlands in SD and southward to Texas the next few days.
Old Sep 22, 2025 | 11:23 AM
Overkill2's Avatar
Overkill2
Drive safe... lots of knuckleheads out there...
SwampJYDod
Apr 6, 2026 11:40 AM
Mike7878
Dec 14, 2019 07:43 AM
2 cowpokes
Aug 10, 2013 11:07 PM
mvimpvm
Jun 23, 2004 10:01 PM
mebsdad
Aug 19, 2003 12:50 AM
