5th wheel capacity question
Old Aug 16, 2025 | 04:27 AM
docderwood's Avatar
docderwood
4th Gear
Why is the 5th wheel towing capacity so much less for this truck (click towing capacity button)?
https://www.ford.com/inventory/detai...6%3A87%3Aexact
Old Aug 16, 2025 | 08:08 AM
OBS460's Avatar
OBS460
I wouldn't consult a website like that for the actual ratings. It could just be 19k because that is what Ford's default 5th wheel hitch is rated at. If you want the real ratings I would look at the RV and Trailer Towing Guide for that year and look for the 5th wheel/gooseneck section and use that number as a base. My 2022 F350 with a 7.3 is rated for 21,500lbs 5th wheel according to the RV and Trailer Towing Guide but according to Ford's website it is only rated for 15k lbs.
Old Aug 16, 2025 | 09:27 AM
Rwhjr's Avatar
Rwhjr
That would be one painful ride with 21k and a 7.3.
It’s crazy what they’ll rate a truck at for the marketing numbers now a days.
Hell I think a srw 350 with PSD can be rated at like 25klbs. now with the right combo.
Old Aug 16, 2025 | 09:55 AM
Joe T's Avatar
Joe T
Probably rear gawr or passenger load they are estimating.
I know with gooseneck, at least for me, its only me in the truck.
Old Aug 16, 2025 | 10:20 AM
Joe T's Avatar
Joe T
Double post
Old Aug 16, 2025 | 03:43 PM
OBS460's Avatar
OBS460
I towed 19k on a gooseneck with it and it actually wasn't that bad. The 6.7 is limited to the tire weight rating or the RAWR or the trucks GVWR.
Old Aug 16, 2025 | 05:41 PM
Willard5.0's Avatar
Willard5.0
Plug in the VIN here. Ford's official page based on your VIN.
Towing Calculator
Old Aug 16, 2025 | 05:45 PM
Kameron Rice's Avatar
Kameron Rice
the 6.7L in the f450s start to struggle pretty hard when you get 30,000lbs or over, engine wise. Handling is great.
Old Aug 17, 2025 | 12:04 AM
docderwood's Avatar
docderwood
4th Gear
Towing Calculator
That's actually what I'm doing, the numbers are from Ford's website.
What I *don't* understand is why the capacity drops from 24,480 for a gooseneck to 19,000 for a 5th wheel? I've been looking at a lot of F350's and not ran into any of them dropping between gooseneck to 5th Wheel?
Old Aug 17, 2025 | 09:11 AM
OBS460's Avatar
OBS460
Like I said, do not go off the website specs. Here is the page straight out of the 2024 RV & Trailer Towing Guide as well as the full PDF of the guide.
Old Aug 17, 2025 | 10:02 AM
Midwest87's Avatar
Midwest87
Pulling 20k, with an SRW, is a pretty dumb thing to do. Those ratings appear to be made by salesman, not engineers that give a darn about anybodies safety.
Its good to stay within the limits, and all. But those numbers are obviously sub-optimal setups. In my experience, if you need the diesel, you need DRW as well. For real towing, DRW is priceless.
Old Aug 17, 2025 | 05:10 PM
Joe T's Avatar
Joe T
Yeah a 20,000lb 5th wheel on a 350 srw can very likely take you over rear GAWR or at minimum put you in a position where you have little leeway.
17,000 is probably the smarter number.
Old Aug 18, 2025 | 05:58 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Something to remember is that fifth-wheel RVs are NOT the same as a typical gooseneck. A typical fifth-wheel RV, even converted to a gooseneck pin, WILL have a heavier tongue weight than your standard gooseneck, and you can't really redistribute the weight like you can on a typical gooseneck because the weight is static - you can't move slides, furniture, cabinets, etc. very easily, not to mention part of the trailer is LITERALLY built over the tongue. With a gooseneck trailer, you have the option of adjusting the load fore and aft (usually) to keep the pin weight closer to something your truck can handle - and if there's ANY weight carried the tongue, it's generally not much because most of them don't have anything OVER the tongue to put something.
RVs and your typical enclosed/flatbed trailers of any kind cannot be compared apples-to-apples.
Old Aug 18, 2025 | 11:26 AM
DPelletier's Avatar
DPelletier
F450 pickup or C&C?
Dave
Old Aug 18, 2025 | 12:05 PM
seijirou's Avatar
seijirou
It's pick your poison really. That guide has less for my cargo than what is on my sticker and on the website, but has more for trailer than what is on the website. So what makes one more authoritative than the other.
