FYI if you find OEM ones, make sure to SEE the FORD stamped on the bottom back side of the mirror body. Like can be seen in the 1st Ebay add. The upper hdwr for the bracket to attach to the top of the door frame are called T bolts. https://www.ebay.com/itm/176187790634
