2019 6.2l P061B Code
Old Aug 12, 2025 | 05:41 PM
PENOBSCOT's Avatar
PENOBSCOT
I have a 2019 F250 with the 6.2l and 6 speed transmission. The truck has 11935 miles on it and when we were towing the boat to the lake this past weekend while at a stoplight the truck lurched then the wrench light came on. I pulled into a parking lot and cycled the key several times and the wrench went away. At the boat the launch my buddy was able to scan for codes and code P061B was in the history. It was smooth sailing on the way home and now the code has cleared 100%. Has anyone out there come across this problem with the 6.2l motors?
Old Sep 4, 2025 | 08:17 PM
Dustyh21's Avatar
Dustyh21
1st Gear
Following
following this. I’m at 165k miles and this exact thing just happen to me. Got it home luckily and **** it off let it sit for 15 and started back up, no lights and running normal. Pulled code P061B on the scanner.
Old Sep 4, 2025 | 09:00 PM
PENOBSCOT's Avatar
PENOBSCOT
Seems like there could be several things this code refers to. My initial thought was the transmission, but reading on the interweb it leads more towards the throttle body and sensors. Was hoping someone here had some information about this. I drove it this past weekend and even towed the boat with no problems at all. Fingers crossed it was a fluke.
Old Oct 28, 2025 | 07:37 PM
PENOBSCOT's Avatar
PENOBSCOT
Curious if anyone has any input on this P061B Code?
Old Oct 28, 2025 | 09:30 PM
SMSTX's Avatar
SMSTX
Pin point tests continue on down multiple paths from checking crank sensors to getting into ABS and vehicle dynamic systems. Also asked about stock tire size and gear ratios. Needs to be professionally diagnosed
Old Oct 29, 2025 | 10:43 AM
PENOBSCOT's Avatar
PENOBSCOT
Thank you for the reply, that is some good information to start with. Fingers crossed it has not happened again. If it does, I will definitely take it in for a diagnosis.
Old Oct 29, 2025 | 05:00 PM
ssmith100's Avatar
ssmith100
My 2018 6.2 has 200,000 on it and still going strong. I had that happen to me twice since I have owned the truck new. Both time I was able to pull over and stop the truck. Cycled the key after it sat for couple of minutes and it was back to normal.
Shane
Frank79
Dec 12, 2023 09:12 AM
rfranzke
30
May 27, 2023 07:10 AM
StrummerK
Apr 29, 2021 10:37 PM
triskadek
Escape & Escape Hybrid
Mar 8, 2010 03:49 PM
That_Guy
Jan 2, 2008 06:45 PM
