M5od rebuild
Old Aug 11, 2025 | 07:01 PM
Dapodaca24's Avatar
Dapodaca24
1st Gear
M5od rebuild
Just finished pulling my m5od out of my 94 f150 I’m getting it rebuilt and want to do a complete overhaul on everything for the transmission. I just want to make sure I get everything so far I have the clutch, pressure plate, pilot bearing, trans mount, rear main seal, flywheel and new bolts shifter rebuild kit throwout bearing and slave cylinder and a Master cylinder. Is there any other seals gaskets or things that I should replace while I have it all torn apart ?
Old Aug 11, 2025 | 08:26 PM
sswari's Avatar
sswari
Make sure they put brass plugs in the top hat of the shifter when they rebuild that part.
That transmission is so easy to rebuild, I did mine.
Old Aug 12, 2025 | 08:04 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I don’t see an actual rebuilt kit listed. Where did you get the overhaul kit for the transmission?
Old Aug 12, 2025 | 09:54 AM
sswari's Avatar
sswari
I had to get the parts that I needed, separate. I was able to take several from a second trans that I found at the UPullUPay.
Old Aug 12, 2025 | 09:59 AM
My4Fordtrucks
I was curious only because I have the M5 I took out of my truck. It shifted good but leaked like a sieve. If rebuilding it wasn’t expensive then it might be worth doing so it’s ready to sell or put away in a corner.
Old Aug 12, 2025 | 10:05 AM
sswari's Avatar
sswari
Yes, if the hard parts are good, it's not that hard or expensive.
Now that I thing about it. I may have bought the bearings as a kit.i will see if I can find it a bit later. But it was 4 or 5 years ago. As for the leaking, probably the plugs on the top hat. The original ones are rubber. You can get some bread freeze plugs to fix that. Other seals will bribable help as well.
There are aa few press on/ cut off parts but nothing overly complicated. I have a step by step document I can send later as well
Old Aug 12, 2025 | 10:22 AM
My4Fordtrucks
No rush. That is a very low priority project.
Old Aug 13, 2025 | 02:45 PM
Truckbuck's Avatar
Truckbuck
I don't know if you want to go "all in" but Rock Auto offers a seal, bearing, and synchro kit for the transmission. I got a clutch kit off of rock auto and it came with the throw out bearing, clutch, and pressure plate. It is better to replace the transmission mount and engine mounts at the same time, just a heads up.
https://www.rockauto.com/en/moreinfo...t=8676&jsn=566
Old Aug 15, 2025 | 09:25 PM
TobyB's Avatar
TobyB
If I had it all torn apart, I'd replace the 2nd and 3rd gear synchros, just because they seem to take the biggest beating...
t
baker1983
Dec 4, 2012 06:09 PM
eclipsewelder
1983 - 2012 Ranger & B-Series
Apr 2, 2009 07:07 AM
agryphon
Dec 27, 2005 11:18 AM
lr
Dec 13, 2002 08:41 PM
