Another dragging caliper thread *Edit for update*
Old Aug 10, 2025 | 03:16 PM
HillyBillyDeluxe's Avatar
HillyBillyDeluxe
I can't figure this out. Replaced the left front caliper because it was dragging and seized up. I dont drive my Excursion much, so I've put off swapping on a new caliper until the other day. Now the pads were in damn near new condition besides driving it about 20mi home when the old caliper started to seize up. Since swapping it, I've only run it aboiy 30mi. Just got back home from town and I can smell brake pad material. I grab the hub and its hot but not crazy. Verify with the temp gun and the rotor is 200deg vs the pass side at 165ish. Everything went together easily, hub spun freely after install. Not sure what I'm missing.
Old Aug 10, 2025 | 04:01 PM
WE3ZS's Avatar
WE3ZS
Could be the rubber hose going to that caliper is internally collapsing holding fluid out in the caliper and causing it to drag some.
Old Aug 10, 2025 | 04:03 PM
01__Excursion's Avatar
01__Excursion
Are the caliper slide pins properly lubed with caliper grease? Which is a specific type of grease to prevent the slide pins from getting stuck in a vacuum and not sliding back out.
Amazon Amazon
https://www.ford-trucks.com/forums/1...in-grease.html
Old Aug 10, 2025 | 05:42 PM
HillyBillyDeluxe
I used a pair of vice grips to squeeze the rubber line to prevent brake fluid from draining out and the rubber didnt seem soft enough to colapse on itself.
https://www.amazon.com/Genuine-Ford-...000NU7OZG?th=1
I popped the rubber covers off and the pins were greased.
I mase sure the little springs were holding the pads just slightly off the rotor. I made sure the actual cyl were pushed out enough to have enough clearance to slide right over and put the caliper bolts back in no issue.
Maybe an air pocket from bleeding? They seemed to gravity bleed way too easy. Like crack the bleeder screw after installing the brake line, and 10sec later fluid was pushing air bubbles out of the bleeder. I let that go until it was just fluid, then did the standard bleeding method with no air bubbles to see.
Old Aug 10, 2025 | 07:05 PM
Dweber85rc's Avatar
Dweber85rc
Collapsed hose or sticky pins are the most likely culprit. My vote is the hose that you pinched....
Old Aug 10, 2025 | 07:12 PM
01__Excursion
Sounds like the flex hoses should be replaced now.
Old Aug 10, 2025 | 07:55 PM
HillyBillyDeluxe
I mean they're only 25yrs old . I'll order a set and probably a front right caliper this week and swap everything out when I get back home in a week or 10 days (truck driver).
Old Aug 11, 2025 | 06:45 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
another vote. ~6yrs ago I was dealing with the same. People here told me and I just refused to believe it. Hoses looked in great condition. I replaced all 5 rubber hoses for about $100 and a few hours. Instantly solved my "little" problem.
BTW, when you say slide pins are greased...as in a lot? or barely enough to seem useful? Lean heavily on the barely enough. ERR to side of caution. Even a dab too much will let them suction/vacuum seal in the pin hole and make them drag. Learned this the hard way. a few times.
Old Aug 11, 2025 | 09:03 AM
DavenTn's Avatar
DavenTn
200* F is not that hot, but I would change the hoses with stainless reinforced lines. Remember the inside of the line is still flexible (Teflon).
Old Aug 28, 2025 | 10:23 AM
HillyBillyDeluxe
I forgot to update this. Got back home and picked up a new brake line, but before installing it, I bled the caliper again and it seems to have cured the issue. Ive only put about 50mi on it, but after driving with it being 95+ deg out, Im only seeing 150ish deg at the hub and maybe 170 on the rotor and there is no more brake material smell.
So I decided to hold off on the lines until I put together all the stuff to lift it.
Old Aug 31, 2025 | 07:44 PM
DavenTn's Avatar
DavenTn
Flush the brake fluid.
Jo7.3
Oct 21, 2019 08:21 PM
quakerj
Oct 5, 2018 12:15 PM
crazyrwe
Nov 5, 2011 07:49 PM
rob_engineer
Aug 15, 2006 08:36 AM
cjcocn
1997 - 2003 F150
Mar 27, 2006 05:25 PM
