Temp gauge reading
Old Aug 7, 2025 | 01:22 AM
Joshf100's Avatar
Joshf100
Temp gauge reading
Hello, I have a 73’ f100 custom and when I acquired the truck the temp gauge was not working due to it being the original and went out. So I replaced the part with a CJ Pony replacement. But the temp is reading below the first line after driving it for 25 mins in 95°-100° desert heat, I have attached a picture to where it reads at and does not go higher from. Please let me know if this may be normal or not or if I have an incorrect Ohms gauge. Thank you all have a blessed one.
Old Aug 7, 2025 | 07:41 AM
meangreen92's Avatar
meangreen92
Looks right to me. "D3" indicates 1973. Next thing to check is the gauge sender. What engine is in the truck?
Old Aug 7, 2025 | 09:22 AM
beartracks's Avatar
beartracks
Reaing is very low. Did you replace the sender unit.
Old Aug 7, 2025 | 02:28 PM
Joshf100's Avatar
Joshf100
Hello, thanks your the reply but According to the vin if it’s still original it should be a 360.
Old Aug 7, 2025 | 02:31 PM
Joshf100's Avatar
Joshf100
thanks for the reply, but I have not replaced the sender unit looks in fairly good condition to me, but then again I don’t know if maybe it could be the original sending unit.
Old Aug 7, 2025 | 03:05 PM
ehewson's Avatar
ehewson
What beartracks said. Check your sending unit. make sure it hasn't been replaced, disconnected, or maybe not working correctly. Might need a multimeter that can measure ohms. 10 ohms = full oil pressure and ~73 ohms for low pressure.
Are you're other gauges working correctly?
Old Aug 7, 2025 | 04:51 PM
meangreen92
If someone swapped in another engine from a vehicle with a warning light instead of a gauge, then it won't work - if they didn't swap the senders.
You can turn the key to accessory or run, and ground the sender wire, from the gauge, and the gauge should peg full hot. There are resistors you can use to test the gauge throughout its range.
Old Aug 8, 2025 | 09:41 PM
FeelthySanchez's Avatar
FeelthySanchez
If still running the OEM Autolite thermostat, have you verified that it is not stuck OPEN?
They are notorious for doing so - sticking opened & closed.
If the engine & radiator seem abnormally cold to the touch after normal driving, you've found the problem.
ajlr712
Jan 15, 2022 07:43 AM
F10N
Mar 5, 2019 07:32 AM
drbobthebuilder
1947 and Older Ford Trucks
May 7, 2005 06:07 PM
jmackie
1978 - 1996 Big Bronco
Sep 6, 2002 06:08 PM
