DTE dropping fast
Old Aug 5, 2025 | 08:34 PM
Stroke 6.7's Avatar
Stroke 6.7
4th Gear
DTE dropping fast
On a trip the other day my DTE ( Distance to Empty) gauge started dropping so fast thought I was dumping diesel on the road. I’ve tried battery disconnect, ET (engineering test) mode, topping off fuel tank several times, draining water and checking fuses. It got down to 3 miles to empty. I heard it would go into limp mode at 0 miles. Anyone else have this issue before?
Old Aug 5, 2025 | 08:55 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I don't think the distance to empty readout will have any effect on the truck running if it bottoms out.
Old Aug 5, 2025 | 11:35 PM
406f150's Avatar
406f150
Can confirm it will not cut power with 0 to empty.
Old Aug 6, 2025 | 05:54 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Yeah the DTE on the fuel gauge won't affect how the truck runs, though it is indicative of a problem if it drops that fast that suddenly.
Now, if it's the DTE on the DEF, yes, that WILL pull power and put you in limp mode. I don't think all trucks have a DTE on the DEF tank so I don't know.
Old Aug 6, 2025 | 09:40 PM
Stroke 6.7's Avatar
Stroke 6.7
4th Gear
Took it to Ford dealership
They said it was fuel pump module in tank. I guess it has an integrated sending unit? Funny thing is they also did recall work for a just released 6.7 Powerstroke recall. We are aware of the fuel pump failures on this engine and I understand that this recall is for reprogramming of the powertrain control module specifically aimed at " improved cooling" for the fuel pump for the purpose of reducing failures. $1500.00 parts and labor! Seems like they knew about this problem beforehand.
Reverend Jim
Dec 27, 2024 07:40 PM
RazorV
Nov 23, 2016 07:31 PM
KDAVID1
Mar 22, 2014 09:02 PM
KC8QVO
6.4L Power Stroke Diesel
16
Oct 20, 2010 01:53 PM
mlee52554
2004 - 2008 F150
Oct 14, 2008 10:45 PM
