Rear Differential Fluid Change
Old Aug 4, 2025 | 08:00 AM
JPG37's Avatar
JPG37
Just changed the read differential fluid on 2016 F150 3.5 ecoboost. This is our work truck and has been on a lot of gravel roads. The fluid came out brown and milky (water in the fluid). Discovered the vent hose was plug at the top from driving on so many gravel roads and not allowing condensation out of the differential. This is the fifth truck (mostly ford, dodge and toyota) that I have worked on that has had a clogged breather vent. All the trucks before the 2016 F150 had oil forced out of seals except this 2016, no leaks, just condensation.
Old Aug 4, 2025 | 08:56 AM
SpencerPJ's Avatar
SpencerPJ
Interesting, never thought of that. Glad you changed it and reasoned out issue. Maybe rig some type of extra air vent, change it yearly?
Old Aug 4, 2025 | 01:04 PM
JKBrad's Avatar
JKBrad
You can buy a breather tube extension online that puts it up near the tail lamp housing. Probably wouldn't be too hard to fabricate one yourself out of vacuum line. You could even use a cheap fuel filter on the end for it to breath through.
Old Aug 13, 2025 | 09:22 AM
danskool's Avatar
danskool
Go Bills !
I hate this board because it makes me so paranoid, Now i have to do mine ! And check that hose. Add to my to do list. Dam it.
Buster Joe Baker
2004 - 2008 F150
Jun 2, 2024 08:53 PM
crispyc21
Aug 5, 2010 10:29 PM
bocomojoe
Dec 1, 2008 01:19 PM
Duderoy
13
Jul 15, 2003 08:45 PM
