Modular V10 (6.8l)
Fuel pump problems
Old Aug 4, 2025 | 01:00 AM
burrbuy's Avatar
burrbuy
3rd Gear
Fuel pump problems
I recently had my fuel pump replaced after a side of the road failure on my Super duty e450 RV. The mechanic was able to knock on the gas tank several times to revive the pump. He then told me that this is indicative of a failing pump, so I had him replace it. I drove home another 300 miles and was able to use the vehicle for a month or so before storing it. When I went to start the motor after the vehicle was stored for about a month, the exact same symptom of fuel starvation repeated itself. I checked fuse, replaced relay with another identical one, and also replaced relay control board, all of which did not fix the problem. I did keep the used fuel pump that was replaced and connected 6V dc to it to confirm the motor worked. I then found the plug for the fuel pump, disconnected it and reconnected the old fuel pump just to see if the problem was in the newly replaced pump or in the signals present at the pump connector. The old pump did not start. This convinced me that the new pump is not the problem. I would like to know what voltage I should be reading at the fuel pump connector pins. I measured no voltage on what I think are the pins that supply voltage to the pump (pink/white wire and black wire), and I read 12 v across two pins, even with the motor off.
Can any one supply me with a wiring diagram, or a description of the fuel pump connector pins and what voltages should be measured when engine is off and then when the key is turned on to first position before start? The four wire colors I have on the 2006 super duty are pink/black, black, yellow/white, and grey.
Thank you for any help!
Old Aug 4, 2025 | 05:21 AM
charlie g's Avatar
charlie g
FTE Community Team
welcome to this site,
to hopefully better aid you,i'm copying your post to the motor home/rv section https://www.ford-trucks.com/forums/forum321/ good luck
Old Aug 4, 2025 | 08:10 PM
burrbuy's Avatar
burrbuy
3rd Gear
Thanks Charlie,
I am new to forums in general, so I appreciate your help by increasing the exposure to my problem. Regarding my problem with the fuel pump, this must be incredibly common. I am very certain that the same general architecture of fuel pump, fuel relay, fuel pump module, etc are common in many Ford trucks including the F150. Can I consider copying my problem over to the very common F150 forum where I am certain to gain a lot of useful information on this subject? If so, please confirm. I do not want to start my forum methodology off on the wrong foot...thanks!
Prez
1997 - 2003 F150
Apr 21, 2015 09:49 PM
DougMcCarty
1997 - 2003 F150
Mar 25, 2013 05:04 AM
maniac152
2004 - 2008 F150
Mar 2, 2008 12:06 PM
protow2000
Aug 12, 2006 11:12 AM
