New codes from FORScan
Old Jul 30, 2025 | 06:55 PM
Kingair90's Avatar
Kingair90
Hello, I just got the FORScan working not the best it seems as if the connection is bad, but I was able to pull these codes.
P0046 / P0673 / P1000 / U1262 / B1352 / P0500 / U2015 AND U2016 / B1342.
Those two last groups are serious.
I just had the PCM repaired a year ago one month to make a year, 785 dollars. if anyone knows a better price on the market, please, let me know.
Regards
K Leerdam
Old Jul 30, 2025 | 07:53 PM
joe blow's Avatar
joe blow
For those that know, what actually ruins a PCM?
I don't hear that as a main issue, it is usually an underlying issue that destroys electronics @Hartwig @TooManyToys. @bismic
Maybe someone can clarify this for me and the OP?
Thanks
Old Jul 30, 2025 | 09:14 PM
bismic's Avatar
bismic
One thing is when people mess with the driver's side battery, they remove the battery plastic cover, which is really a PCM cover. Then if/when the degas bottle vents coolant, it can get on the PCM connectors.
Also, heat is not good for electronics, so I suppose excessive engine heat can cause problems as well.
Old Jul 31, 2025 | 06:32 AM
TooManyToys.'s Avatar
TooManyToys.
And age. Our trucks are getting up there. The seals on the PCM can shrink, and some humidity can get in there. But electronics have a life span, which has a bell curve.
Mark's point about the shield missing on so many driver batteries, leading to the potential of connector corrosion. AGMs help reduce this concern, and so do batteries like mine, where I've never seen terminal post leakage and my vents go to a nipple on the short side of the battery where a rubber hose can connect and vent away from the upper engine compartment. Hence, I don't use that cover.
B1GKAHUNA
Apr 11, 2025 09:31 AM
Joshb2020
6.7L Power Stroke Diesel
Jun 13, 2024 04:19 PM
cathlabdog
Oct 25, 2006 07:20 PM
Racerguy
1997 - 2003 F150
Mar 25, 2003 07:56 AM
