Fuel Starvation (temporary)
Old Aug 1, 2025 | 10:50 AM
  #61
BigBlue2's Avatar
BigBlue2
When trouble shooting using the parts catapult, I try to limit it to one part at a time so I know which parts catapult deployment worked.
Old Aug 1, 2025 | 11:47 AM
  #62
Max Capacity's Avatar
Max Capacity
Hopefully, he is currently installing the new pump, as the spacers will be a few days...? I assume he knows to start the truck and drive with the new pump ?
Old Aug 1, 2025 | 11:53 AM
  #63
Larry115's Avatar
Larry115
I will do it in that order exactly! I’m learning…slowly but learning and I have all of you to thank
Old Aug 1, 2025 | 01:26 PM
  #64
BigBlue2's Avatar
BigBlue2
With the fuel pump on the frame rail, it's going to be at the same elevation as the fuel tank, so no suction lift involved, only a little bit of friction head loss to the pump. Should be zero vapor lock issue there. It was mentioned that the fuel goes up out the top, but then it goes back down to the pump, so it balances on elevation change.
If you have 100 feet of garden hose and you want to water on the other side of your house, would you have more water pressure going around the house or over the top of the roof, to the same place?
Old Aug 4, 2025 | 04:44 PM
  #65
Max Capacity
FWIW, about the full fuel filter, at a car show, I saw an old Chevy with a full inline filter, sitting right there on top of the V8 intake manifold. So some filters do get fully full, so it is a thing...
Let's hope we get an update from Larry soon.
Old Aug 4, 2025 | 07:01 PM
  #66
FuzzFace2's Avatar
FuzzFace2
When I was working out the brake problem I had and was under the hood I seen mine was half full or is that half empty
I have seen them almost empty dont think I seen one full?
Dave ----
Old Aug 4, 2025 | 07:42 PM
  #67
Denzil B's Avatar
Denzil B
air bubbles are kinda common, but the ones i had were always 3/4 or more full when working right.
Old Aug 4, 2025 | 09:50 PM
  #68
BigBlue2's Avatar
BigBlue2
Air has a way of finding high points in fluid tubes. Since the diameter of the filter is greater than the fuel line the fuel flow can't sweep out the air. Other high points will do the same thing, but over time the air gets swept out. I think you could remove the fuel line from the carb and hold it straight up while bumping the starter or turning on the key with epumps and the air would purge out. Then hold your finger over the fuel line and reattach it and straight away start the engine. That would probably get rid of the air bubble if you wanted to. But as long as adequate fuel goes in and out of the filter there would likely be no performance difference between partially and fully full.
Old Aug 5, 2025 | 06:30 AM
  #69
FuzzFace2's Avatar
FuzzFace2
I would think once the system has been running the air would be purged out.
If you are seeing air bubbles coming into the fuel filter after the fuel pump the pump is sucking it air from some place and has to be fixed.
Any air that may be in the system once it hits the carb float bowl it will go out the bowl vent so fuel can enter.
Again if you are seeing air bubbles entering the fuel filter you got a problem where the pump is pulling in air.
BTW I had a car that would run out of gas under a heavy load. The short rubber hose from tank sender to metal line had cracks but no gas leaked out of it.
Dave ----
Old Aug 5, 2025 | 08:32 AM
  #70
Larry115's Avatar
Larry115
Originally Posted by BigBlue2
I thought he stopped on the way home and let it sit while visiting. Then it wouldn't start. Larry how did it go? I don't want to reread the thread.
We don't know how the fuel line is routed. Maybe it is getting a lot hotter than a normal fuel line run?
hey everyone we had our Granddaughter here visiting so my truck has just sat. The spacer did arrive yesterday so either today or tomorrow I’ll get busy installing it and putting on the new fuel pump.
Old Aug 5, 2025 | 08:36 AM
  #71
Larry115's Avatar
Larry115
Hey I’m not sure if everyone saw my reply ref our Granddaughter has been here visiting. We got super busy riding horses, side by side and visiting Yellowstone. The 1” spacer arrived yesterday. Today or tomorrow I’ll install the spacer and new fuel pump. I figured since I had the fuel pump I’d just install it so I know the age etc.. Any suggestions before I get started?
Larry
Old Aug 5, 2025 | 08:40 AM
  #72
Max Capacity
Do one job at a time. Then start the truck and drive it to make sure all is good. Do not change both parts at the same time.
Old Aug 5, 2025 | 02:50 PM
  #73
Larry115's Avatar
Larry115
10-4 I’m glad I checked my post because I’m heading out there now. Thank u
Old Aug 5, 2025 | 03:04 PM
  #74
BigBlue2's Avatar
BigBlue2
Well, we'll have to hold our horses. While you and the grand daughter ride yours!...
Old Aug 5, 2025 | 07:00 PM
  #75
Larry115's Avatar
Larry115
Well I got the 1” spacer on. Drove up the canyon a good ways to get the engine hot, came home and shut the engine off. Let it sit for about as long as I was in Ace Hardware the other day when I came out and had starting issues. This time…..drum roll….my truck started up with no cranking required. Now should I still go ahead and replace the fuel pump? It’s a quick job and I can’t return it because I destroyed the packaging 🙄😝
