Help Diagnose Noise
Old Jul 19, 2025 | 10:41 AM
Baker_Shenanigans's Avatar
Baker_Shenanigans
Help Diagnose Noise
When under load, 8-10 psi and above, there is this chirping/squeaking sound that is produced. I recently replaced my stock turbo with a KC turbo. It made this sound before with the stock turbo as well so I don’t believe it is turbo related? I grabbed this short clip last night on the way home from a softball game. I’ve done leak tests after latest install and everything was good.
any insights would greatly be appreciated.
Last edited by Baker_Shenanigans; Jul 20, 2025 at 08:01 AM. Reason: Added better video clip
Old Jul 19, 2025 | 11:26 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Sounds like some sort of contact. Maybe inspect the fan, see if it's wobbly.
I'd say motor mount but those very rarely go bad on a 7.3.
Old Jul 20, 2025 | 07:28 AM
BillyBob69's Avatar
BillyBob69
Yeah that sounds like metal on metal. I would check the tensioner and idler pulleys. They do wear their bearings out regularly and it sounds like something is about give up the ghost.
Also, if your AC was on while recording, turn it off and listen again. Could also be the blower motor/fan .
Old Jul 20, 2025 | 08:01 AM
Baker_Shenanigans
Thanks gents for the areas to check. I didn’t think about fan or pulleys being a culprit since it didn’t do it at idle or low load.
Here is a little better video that I record yesterday that’s a little longer. Just forgot to upload.
Old Jul 22, 2025 | 10:19 AM
Baker_Shenanigans
Well it’s not the ac compressor. I turned off the ac this morning and noise is still present
Old Jul 22, 2025 | 10:21 AM
Baker_Shenanigans
Also, I recently changed the tensioner when I changed the belt. Again, there before the change and after. I do have a idler pulley on hand and could try that but it sounds like it’s coming from near the firewall
Old Jul 22, 2025 | 11:57 AM
RacinJasonWV's Avatar
RacinJasonWV
Starter bolts backing out letting the snout hit the flex plate?
Just a wild guess since it’s done this with 2 different turbos.
You could pull the belt for a very short test. If it still makes the noise then it’s not in the accessory drive system. I assume you can make this noise sitting still while loading the engine?
Old Jul 23, 2025 | 01:38 AM
aawlberninf350
It's a Van Gogh
Pulling the belt for a test run sounds like a good idea.
Old Jul 24, 2025 | 09:29 AM
FordTruckNoob's Avatar
FordTruckNoob
Does the frequency of the chirp correspond to the engine RPM or boost?
Jay94250
Aug 8, 2012 08:41 PM
o3stroker
Dec 23, 2010 10:02 AM
abealex
Jan 16, 2007 09:00 PM
