General Automotive Discussion
Rough idle fix?
Old Jul 15, 2025 | 07:43 PM
Desertwolf242's Avatar
Desertwolf242
1st Gear
Rough idle fix?
Hello everyone, I have a 1994 f-150 xl 4.9 5spd that has a stumble on idle. Doesn't matter if it's cold or hot. There's also an intermittent issue where it runs TERRIBLE, like it's starving for fuel or something. A quick "fix" i discovered for that (out of frustration) is to rev the thing up around 4500-5000 rpm and it just settles down but still stumbles. I have no idea.
I've replaced the distributor, plugs, wires and fuel injector harness (it was eaten by mice) I've checked all vacuum lines and done a smoke test and found no leaks. I've also checked all the wiring under the hood, nothing is frayed or unpinned from a connector. Any help is appreciated thanks in advance.
Old Jul 15, 2025 | 09:19 PM
Truckwardo's Avatar
Truckwardo
Test the fuel pressure. Dynamically if you can.
Old Jul 15, 2025 | 10:13 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Might want to start a new thread in the 1987 - 1996 F150 & Larger F-Series Trucks forum. They'll be able to help you out.
Old Jul 19, 2025 | 10:14 AM
beartracks's Avatar
beartracks
Clean the throttle body.
dogerbrown1
Mar 9, 2024 07:23 PM
james_1988f250
Oct 27, 2022 05:43 PM
Joeyb31502
Jun 1, 2021 11:56 PM
Plankton
Aug 12, 2020 06:50 PM
uy7v
13
Feb 28, 2002 11:31 AM
